Home > Technical > Huge Fuel leak
Page 2 of 2 <12
x-isle
2 pipes are diesel (in and out) and the other 2 pipes are coolant from the engine. Of course, the 2.2 that doesn't have the cooler don't have the water pipes. Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #403200 1st Mar 2015 12:35am
LittleFoot
Thanks for the advice X-Isle.
Hopefully will get an idea of problem from dealers tomorrow but based on where fuel was leaking suspect you're likely to be right.
Post #403448 1st Mar 2015 7:33pm
LittleFoot
Dealer mechanic found one of the fuel lines detatched as X Isle suggested. He also suggested that as the 2.2 has a low pressure fuel pump this would potentially allow vehicle to run normally therefor not giving a warning! He did say there was no reason he could see why the hose had detached.....
Post #404540 4th Mar 2015 8:57pm
x-isle
Awesome! Thumbs Up
Glad it was as I thought. I bet it just was never put on properly and finally decided to pop off.
Did you find out if you have a cooler or just the pipes? Craig Rogers
2007 Puma 110 XS
Post #404559 4th Mar 2015 9:47pm
dgardel
Italy
entreq plate on mine...
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #404679 5th Mar 2015 11:37am
x-isle
I don't quite understand the Entreq plate.
It's supposed to protect both the oil filter and fuel cooler.
However, in that 2nd photo you can clearly see oil filter housing? So it looks like things can still be thrown up from the front wheels and hit the oil filter.
I've got the D44 fuel cooler guard and I'm going to make my own oil filter guard. Craig Rogers
2007 Puma 110 XS
Post #404684 5th Mar 2015 11:46am
LittleFoot
Just bought an Allmakes one from MPS Thumbs Up
Thanks guys.
Post #404804 5th Mar 2015 8:39pm
Page 2 of 2 <12
