Home > Technical > Huge Fuel leak
LittleFoot
Huge Fuel leak
Hi folks,
My 110 has just decided to chuck fuel out all over the road, at a tremendous rate and been dragged off to the dealers on the back of a recovery truck. Only occurred when the engine was running and fuel was literally pouring out from under the mid/rear of the engine. Nothing visible up top or down side of engine....lost 30-40 litres in a few miles....running didn't seem effected though?
It was booked into dealer anyway as I thought it had just started sounding noisier and more rattly recently...2012 with 21k.
Any ideas?
LittleFoot
Post #403081 28th Feb 2015 5:53pm
PCA42
England 2008 Defender 110 Puma 2.4 DCPU Tonga Green
Mine's got a slight leak from the fuel pressure regulator on the back of the injector manifold that I haven't managed to cure. There's the valve itself, an adaptor piece that screws into that, then a plastic clip on fitting for the pipe on the back of that.
Maybe coming from around there somewhere? Pete
2010 Discovery 4 GS TDV6
1972 Series III 88" 2.25P
Post #403091 28th Feb 2015 6:22pm
x-isle
Could be the fuel cooler, or the fuel pipes where the cooler was if it's a 2.2. This is attached to the chassis at the rear of the engine and are prone to damage. Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #403097 28th Feb 2015 6:46pm
LittleFoot
Hi X-Isle, it's a 2.2 puma - thanks for the tip.
Post #403099 28th Feb 2015 6:49pm
x-isle
Yes, sorry noticed the date at the end so edited my original post. Craig Rogers
2007 Puma 110 XS
Post #403100 28th Feb 2015 6:50pm
SGH
Re: Huge Fuel leak
LittleFoot wrote:
Hi folks,
My 110 has just decided to chuck fuel out all over the road, at a tremendous rate.
Any ideas?
LittleFoot
And on my drive... Rolling Eyes
That's the second time it's broken down at my place, last time it was intercooler hose.. Laughing 993 Varioram - Guards Red
Defender 2.5 300TDI 110 HCP - Keswick Green
Defender 2.2 TDCI 130 HCP - Orkney Grey - GONE
Discovery 4 SDV6 HSE LUX - Corris Grey/Black Pack - GONE
Discovery 4 SDV6 HSE LUX - Montaciano Red/Black Pack - GONE
Post #403118 28th Feb 2015 8:01pm
dorsetsmith
two thing under 2.2 and 2.4 land rover that can be damage Exclamation
Post #403128 28th Feb 2015 8:23pm
if you can get one, an entreq fuel cooler guard is the answer, it would fully protect the oil filter and fuel cooler
Post #403130 28th Feb 2015 8:29pm
x-isle
Strangely enough, I first read the post just after fitting my D44 Cooler Guard Craig Rogers
2007 Puma 110 XS
Post #403146 28th Feb 2015 9:07pm
leeds
Guess who might just have one or two on their shelves Whistle
Brendan
Post #403150 28th Feb 2015 9:20pm
LittleFoot
"And on my drive... Rolling Eyes
That's the second time it's broken down at my place, last time it was intercooler hose.. Laughing"
That's bloody true.....Must be cursed Rolling with laughter hope it came off ok?
was thinking about one of those guards anyway but vehicles been sitting for 2 weeks so bit strange to say the least....unless Mrs has been using it in my absence Big Cry
Post #403151 28th Feb 2015 9:22pm
x-isle
Maybe just one of the speed clips has popped off? Doesn't normally happen but it might not been on fully? Craig Rogers
2007 Puma 110 XS
Post #403153 28th Feb 2015 9:24pm
LittleFoot
Am I correct in thinking the rectangular module with several hoses coming off it is the fuel cooler? I can see why the guard could be a good idea....that looks very vulnerable.
Hopefully its just a clip like you suggest!
Post #403155 28th Feb 2015 9:28pm
x-isle
That's right, that's the cooler.
However as yours is a 2.2, you might not have the cooler, just the pipes as they removed it at some point on the 2.2. The pipes are still vulnerable.
Here's the d44 guard fitted to protect them without a cooler.
The reason of my thinking it's these pipes is that it's the return to the tank, therefore a leak here probably won't affect the engine. Craig Rogers
2007 Puma 110 XS
Post #403161 28th Feb 2015 9:40pm
Simon27
Scotland 2009 Defender 90 Puma 2.4 SW Tamar Blue
I always wondered that that box was on mine!
Post #403177 28th Feb 2015 10:20pm
