Home > Technical > Huge Fuel leak |
PCA42 Member Since: 15 Jun 2014 Location: Church Stretton Posts: 468 |
Mine's got a slight leak from the fuel pressure regulator on the back of the injector manifold that I haven't managed to cure. There's the valve itself, an adaptor piece that screws into that, then a plastic clip on fitting for the pipe on the back of that.
Maybe coming from around there somewhere? Pete 2010 Discovery 4 GS TDV6 1972 Series III 88" 2.25P |
28th Feb 2015 6:22pm |
x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327 |
Could be the fuel cooler, or the fuel pipes where the cooler was if it's a 2.2. This is attached to the chassis at the rear of the engine and are prone to damage. Craig Rogers
2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography Last edited by x-isle on 28th Feb 2015 6:50pm. Edited 1 time in total |
28th Feb 2015 6:46pm |
LittleFoot Member Since: 25 Aug 2012 Location: east sussex Posts: 233 |
Hi X-Isle, it's a 2.2 puma - thanks for the tip.
28th Feb 2015 6:49pm |
Yes, sorry noticed the date at the end so edited my original post. Craig Rogers
2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
28th Feb 2015 6:50pm |
SGH Member Since: 27 Sep 2010 Location: Hellingly-Sussex Posts: 1527 |
And on my drive... That's the second time it's broken down at my place, last time it was intercooler hose.. 993 Varioram - Guards Red Defender 2.5 300TDI 110 HCP - Keswick Green Defender 2.2 TDCI 130 HCP - Orkney Grey - GONE Discovery 4 SDV6 HSE LUX - Corris Grey/Black Pack - GONE Discovery 4 SDV6 HSE LUX - Montaciano Red/Black Pack - GONE |
28th Feb 2015 8:01pm |
Click image to enlarge two thing under 2.2 and 2.4 land rover that can be damage |
28th Feb 2015 8:23pm |
if you can get one, an entreq fuel cooler guard is the answer, it would fully protect the oil filter and fuel cooler
28th Feb 2015 8:29pm |
Strangely enough, I first read the post just after fitting my D44 Cooler Guard Craig Rogers
28th Feb 2015 9:07pm |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8578 |
Guess who might just have one or two on their shelves Brendan |
28th Feb 2015 9:20pm |
"And on my drive... Rolling Eyes
That's the second time it's broken down at my place, last time it was intercooler hose.. Laughing" That's bloody true.....Must be cursed hope it came off ok? was thinking about one of those guards anyway but vehicles been sitting for 2 weeks so bit strange to say the least....unless Mrs has been using it in my absence |
28th Feb 2015 9:22pm |
Maybe just one of the speed clips has popped off? Doesn't normally happen but it might not been on fully? Craig Rogers
28th Feb 2015 9:24pm |
Am I correct in thinking the rectangular module with several hoses coming off it is the fuel cooler? I can see why the guard could be a good idea....that looks very vulnerable.
Hopefully its just a clip like you suggest! |
28th Feb 2015 9:28pm |
That's right, that's the cooler.
However as yours is a 2.2, you might not have the cooler, just the pipes as they removed it at some point on the 2.2. The pipes are still vulnerable. Here's the d44 guard fitted to protect them without a cooler. The reason of my thinking it's these pipes is that it's the return to the tank, therefore a leak here probably won't affect the engine. Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
28th Feb 2015 9:40pm |
Simon27 Member Since: 30 Oct 2012 Location: East Lothian Posts: 131 |
I always wondered that that box was on mine!
28th Feb 2015 10:20pm |
