Home > Td5 > Vibration at 50 mph
Kent_keith
England 2005 Defender 90 Td5 CSW Zambezi Silver
Vibration at 50 mph
My rear UJ was replaced due to wear by a Local Land Rover garage 2 weeks ago and straight away I felt a slight vibration at around 50 mph in 5th when going up a slight gradient, cured by putting my foot down a bit, but driving it yesterday it's getting worse, any ideas chaps? Thanks
Just to add its done 50,000 miles 2005 TD5 90 CSW XS
Post #403226 1st Mar 2015 8:16am
Most probably not balanced
But if you have lifted or lowered or changed wheel/ tyre size dramatically can be a factor
Post #403230 1st Mar 2015 8:50am
Kent_keith
I've not/had anything changed but the UJ, silly question then, does the UJ need balancing after fitting? 2005 TD5 90 CSW XS
Post #403237 1st Mar 2015 9:00am
I'm not sure, I bought a new front and rear prop for my tdi and just fitted with no need to balance.
I lowered by 110 tdci and experienced front prop shake at 100kmh, removed -2" rear springs and put on std and went away.
the suspension geometry is carefully thought out on the defender.
another possibility is the steering damper ...
Post #403256 1st Mar 2015 10:01am
dorsetsmith
my back uj had failed rear prop off and had new uj fitted re-fitted prop drive away Thumbs Up
Post #403259 1st Mar 2015 10:07am
munch90
maybe the yokes are not aligned as they should be ?
and to be honest its easy to make a cock up when fitting a uj and end up with a tight bearing on one post Whistle
worth getting both checked
Post #403263 1st Mar 2015 10:14am
Kent_keith
Thing is, I paid a garage to replace it so I expected them to know what they were doing, I plan to take it back next week I suppose I'll find out then Thumbs Up 2005 TD5 90 CSW XS
Post #403308 1st Mar 2015 1:04pm
calum
United Kingdom 2004 Defender 90 Td5 SW Zambezi Silver
Could be loose bolts or something not right with the job done when replacing the UJ. Make sure they use new nyloc nuts.
Calum
Post #403524 1st Mar 2015 11:29pm
Kent_keith
Thanks Calum, I'll ask the question when it goes back sometime this week 2005 TD5 90 CSW XS
Post #403553 2nd Mar 2015 7:43am
austinhealey55
2003 Defender 110 Td5 HT Chawton White
(edited to correct)
The front UJ's should be installed out of phase, meaning the yokes don't line up. IIRC it's about 45 degrees out of phase in the front, but if you google it you'll find it I'm sure. I think in general UJs are usually aligned in-phase (yokes match) on many cars/trucks, so especially if you have more vibration after it's likely they are out. I did mine a while back and had to spend some time getting the phasing correct.
Post #405360 7th Mar 2015 7:04pm
Retroanaconda
Rears should be in phase, i.e. lined up. Fronts should be slightly out of phase.
The difference is due to the angle of the front diff nose being slightly upward toward the transfer box, whereas the rear axle has its diff nose on a parallel plane to that of the transfer box. On the rear the angles are opposite and equal, and so the oscillations in rotational speed inherent to UJs are evened out, on the front the difference in angle means that the phasing is set to smooth out the oscillation as much as possible.
The amplitude of the oscillations is proportional to the angle of the UJ joint, which is why when you lift a Defender too high it starts vibrating.
Post #405577 8th Mar 2015 12:51pm
austinhealey55
Thanks for the correction. It has been two years since I did mine and went out to look at my 110 this morning to remember which was which.
Post #405583 8th Mar 2015 1:17pm
Freypal
United Kingdom 1992 Defender 90 200 Tdi HT Portofino Red
Proposhafts have balancing weights on them also. I'd check this hasn't been knocked off.
Managed to do so on my own 90.
Post #405613 8th Mar 2015 3:04pm
Kent_keith
Thanks chaps for your help, I took it back to the garage and he said there's nothing wrong with it? Now I have to take it to someone else to see if this is the cause or not. Evil or Very Mad I do wish I knew more about defenders. 2005 TD5 90 CSW XS
Post #405941 9th Mar 2015 1:00pm
