Home > Wheels & Tyres > 255/85R16 on Sawtooth |
100inch Member Since: 15 May 2012 Location: Brunswick Posts: 408 |
Has anyone 255/85R16 KM's fitted on Sawtooth's?
How do they look?? m |
12th Feb 2015 8:59am |
Hi ken,
Top service Thanks! Hmmm, I think I go with the 255 then. They just seem to look 'right' on a 110. m |
12th Feb 2015 12:39pm |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3334 |
I'm currently running 255 KM2s but on twisted alloys with a bit more offset, pics below:
12th Feb 2015 1:00pm |
Thanks camelman.m
12th Feb 2015 2:13pm |
johnszs Member Since: 16 Aug 2010 Location: Hereford Posts: 459 |
Anyone got a better side on view?
Ideally on a 90 Cheers john 2004 TD5 Defender 90 xs station wagon |
12th Feb 2015 2:21pm |
rich Member Since: 08 Dec 2012 Location: automotive trim tech trim shop Posts: 264 |
im running 235 mtr's and with 30mm spacers on the 90 and they look good
12th Feb 2015 2:31pm |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1826 |
Not on Sawtooths, but the original Freestyle alloys. (255/85 KM2) Click image to enlarge Click image to enlarge Click image to enlarge Cheers Simon |
12th Feb 2015 4:01pm |
juju60130 Member Since: 31 Dec 2007 Location: france Posts: 11 |
Couplands
hello, your 90 is beautifull. I am interresting in the same roll cage of you. It's a safety devices 142? Are you happy with it? Have you ohters pictures? ( inside, chassis , front leg)? Thanks you. |
13th Feb 2015 10:39am |
Thanks...
Yes, its a Safety Devices 142 http://www.safetydevices.com/expedition/pr.../280/1784/ (like this, but no diagonal brace on the main hoop). It has a wire mesh guard fitted across the main hoop to stop all the kit flying forward. Sorry, I cant get pictures of the chassis fitment as its behind the wheel arches, but the diagram in the link above shows how they fit. Its a LR Special Vehicle build from new, they fitted it and I bought it when 2 years old. Had it for the last 12 years. If I was doing another (and I might) I would get the full external cage as I've had a few close shaves with trees when laning and the extra protection would be worth while. See photo.. Click image to enlarge cheers simon |
13th Feb 2015 12:07pm |
Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435 |
Do the 255's on a standard height suspension 90 catch/rub at all?
13th Feb 2015 1:26pm |
Thanks you for your reply, an other question.
The parts on the chassis is welded or secure with bolt? Good picture |
13th Feb 2015 1:27pm |
They don't catch/rub at all on mine. Standard wheels & offset. cheers simon |
13th Feb 2015 7:25pm |
Its all bolted to the chassis, I've removed the rear hoop and it was a tight fit..! I'm told its best to have roll cages professionally fitted as they are so strong that if you don't get them properly aligned it can bend the bodywork when you tighten the bolts up... cheers simon |
13th Feb 2015 7:32pm |
Ok thanks you. Bye.
13th Feb 2015 10:29pm |
