Home > Puma (Tdci) > PUMA MY2014 junction box battery relay identification
TonoDef
France 2014 Defender 90 Puma 2.2 SW Santorini Black
Hello all,
I've probably missed something obvious so far in the various doc that I have (owner's manual, microcat, electric library, wiring diagrams), but I can't find anywhere a map detailing each relays position ! Can somebody help me please? see attached photo. (Fuse position is indicated though but not relays).
What I've read on the forum about stolen parts and motors kind of scared me, and although we don't seem to have that kind of issue in my sector (North France) : better be prepared than sorry as you guys say ! So I'm in the processe of "layering" the security on my def. Ardcase has been ordered, Stoplock already in place, epoxy for bonnet and door screws is alsmost done, as well as bonnet cable lock protection plate. Now is the time to fit an hidden cut off switch (starter relay or fuel pump I have not decided yet), hence the request !
If you consider the answers are too sensitive to display on a public forum, well do not hesitate to PM me. (As well with additional ideas or suggestions I did not get from the various topics on the subject).
Thanks a lot Thumbs Up
Post #385153 5th Jan 2015 4:42pm
LesDef
Hi TonoDef,
Please see below a list of relays numbered as per your photo:-
1 = R100 Main
2 = R104 Power
3 = R117 Cooling Fan
4 = R123 Headlamp
5 = R138 Heated Rear Screen
6 = R134 Front Wipers
7 = R103 Fuel Pump
8 = R102 Starter
9 = R176 Blower
10= R181 A/C Comp. Clutch
Hope this helps.
Regards LesDef
Post #385404 6th Jan 2015 10:29am
zone30
Belgium 2011 Defender 110 Puma 2.4 X-Tech LE Nara Bronze
Quote:
4 = R123 Headlamp
So the headlamps are relayed now? No need for a swedish cable loom?
Post #385405 6th Jan 2015 10:34am
There has always been a relay in the circuit for Defender headlights - it is energised by "ignition on" and ensures that the headlights only come on with the ignition. It doesn't alter the fact that the full headlight current passes through both the light switch and the high/low beam (dip) switch.
The high-current contacts of the relay are in series with the two manual switches.
Post #385411 6th Jan 2015 10:58am
TonoDef
It does, thanks LesDef, really appreciate it.
Did you got the solution by looking at the wires or Have I missed a document somewhere ?
Thanks again Thumbs Up
Post #385450 6th Jan 2015 1:45pm
zone30
ok, thx
Post #385451 6th Jan 2015 1:47pm
LesDef
Hi TonoDef,
I have moved the under drivers seat (RHD) electrics to a box inside the cabin under the centre consule.
During the proccess I noted the wire colours to each of the relays and checked them against the wiring diagram.
I have not found any documents to designate these relays.
Simple for an Electrical Draftsman.
Regards LesDef
Post #385784 7th Jan 2015 6:21am
TonoDef
That's what I call a real job ! You go diving with yours ? Laughing
Have a good one Les !
Post #385787 7th Jan 2015 6:40am
nitram17
LesDef wrote:
Hi TonoDef,
Regards LesDef
i know tihis is an old post but do you have any pictures of your work?
Post #616779 14th Apr 2017 1:52pm
LesDef
Gidday nitram17,
No photos of my work, at the time I was in a hurry preparing to for a trip across the Simpson Desert.
You can check out the Ex-box at http://www.expeditioncentre.com.au/exbox~4516
Don't know if your at Newcastle pommieland or NSW which will effect viability.
Regards LesDe
Post #620539 30th Apr 2017 2:23pm
Fifth Horseman
Not completely true since 2012 model year. Whilst the dip switch does carry the full lighting current (and is still the weak link), the headlamp switch now operates the relay in the junction box. The relay that enables the headlights with the ignition on is by the main fuse box (bottom row, right hand side)
Post #620643 30th Apr 2017 10:14pm
Pickles
Fifth Horseman,...does that mean that the headlight switch in post 2012 Defenders is not so "vulnerable"?
Pickles.
Post #620668 30th Apr 2017 11:51pm
Fifth Horseman
Yes, the main switch now only carries the current for the sidelight circuits and activates the additional headlamp relay. There was a tech bulletin to bypass the main switch with a relay on earlier vehicles. https://www.defender2.net/gallery/albums/u...0relay.pdf
Shame L/R didn't use relays to bypass the dip switch, but then that would give us nothing to modify....
Post #620695 1st May 2017 8:07am
Maverick90
United Kingdom 2007 Defender 90 Puma 2.4 SW Indus Silver
Is one of the relays shown the glow plug relay and does anyone have a part number for them?
Post #681946 26th Jan 2018 8:17pm
Interesting thanks. I didn't know about that TSB.
A very complex way to do half a decent job!
Post #681960 26th Jan 2018 9:02pm
