Home > Puma (Tdci) > Bloody Dent |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19696 |
Is the paint damaged?
3rd Jan 2015 11:19am |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2729 |
you may find that on a really cold day it just pops out haha.
happened to me when someone sat on the wing and pushed it in a little. Came out one morning with a thick frost and very cold and it was gone - i assume it was the cold at least? Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
3rd Jan 2015 11:22am |
Gleaney Member Since: 03 Dec 2012 Location: Earth! Posts: 94 |
No the paints not cracked. I'm just very protective over her!
3rd Jan 2015 11:24am |
CatherineF Member Since: 22 Nov 2014 Location: Wiltshire Posts: 762 |
Dent Removal specialist. When I got my RCZ I took her to such a place in Swindon, they actually found 3 in total and took them all out for £45 2015 Audi Q3 Quattro S Line Plus 184 TDI Stronic
2010 90 SMC Over Land Nero Edition - Santorini Black Metallic (Now Departed) |
3rd Jan 2015 11:27am |
I don't think a dent specialist could do anything anyway because when you lift the bonnet up there is like a second skin of fabrication and the dent is directly above that. So you could get any tools to the underneath to push it out
3rd Jan 2015 11:35am |
As you rightly mentioned the bonnet is double skinned in a lot of places. Take it for a specialist opinion, if they can get to the back of it you may even get change out of £50 for the repair. Had the same conundrum with a three week old Audi, they stated if they can get to the rear of it they could fix it!
Being an 'Earth Dweller' could you not nip off to some other distant solar system with advanced technology and get it sorted there perhaps? If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
3rd Jan 2015 11:50am |
Hhaaaa nice one. I think my planet is out of kryptonite !
3rd Jan 2015 11:59am |
Would need to be a job where a puller was used, issue there is would need re-painting.
3rd Jan 2015 12:16pm |
Katoom Member Since: 07 Dec 2013 Location: Devon Posts: 25 |
Depending on the type of dent, a pro might be able to draw it out using suction.
3rd Jan 2015 12:25pm |
That's the sort of thing I was thinking. ^^^^ The bonnet being steel though and pretty thick at that might be easier said than done.
I suppose if it's larger it might work out better than a small dent. |
3rd Jan 2015 12:37pm |
I think that's what happened with my RCZ as it was right on a crease where I think there was some reinforcement behind it. 2015 Audi Q3 Quattro S Line Plus 184 TDI Stronic
3rd Jan 2015 1:06pm |
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3471 |
Instead of speculating what might or might not be possible get one of the specialist to have a look, they have ways and means of dealing with these things and cope with double skins and difficult access all the time. Steve.
3rd Jan 2015 1:08pm |
Happy New Year MoG......
+1.... ..... If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
3rd Jan 2015 1:14pm |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5086 |
Not a problem, very good instructions here on how to Make Your Own Kryptonite Make Your Own Kryptonite https://therobotfix.wordpress.com/2012/05/...ryptonite/ Click image to enlarge |
3rd Jan 2015 2:23pm |
