Home > Puma (Tdci) > Paint Flaking off Underneath Arch Extension!? |
Usual...."They all do that Sir!"
http://www.defender2.net/forum/topic3114.h...ing+arches If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
29th Dec 2014 5:47pm |
sweepc Member Since: 19 Jun 2011 Location: uk Posts: 568 |
yes this happens along with various other niggles that we have to put up with I wouldn't worry about it although it is quite annoying
29th Dec 2014 5:50pm |
Xelr8 Member Since: 26 Aug 2014 Location: Sheffield Posts: 165 |
Oh Ok
That makes me feel a bit better I suppose you could have just said......... Welcome to Defender Ownership |
29th Dec 2014 5:52pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19684 |
Yes it happens, will never creep to visible areas though.
Thanks for the replies guys
29th Dec 2014 5:53pm |
Is 'visibe' french? Happy New Year nearly Steve......bonne année!
Welcome to Defender ownership, have you checked your gulleys for any other parts that may have dropped off apart from paint flakes? If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
29th Dec 2014 5:55pm |
Mal - Bloody iPad, it got it wrong first time but I thought I corrected it obviously I did afterwards too.
29th Dec 2014 6:07pm |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3755 |
Yes, I was told (by this forum!) that it's totally normal. Happened to ours (still is), & I too was worried that it would spread to visible areas.
Pickles. |
29th Dec 2014 10:01pm |
Iktank Member Since: 08 Nov 2014 Location: Porthcawl Posts: 236 |
And to confirm mine is also peeling
concerned at first but as advised it is only within the arch and has not spread further |
29th Dec 2014 10:11pm |
I'd hazard a guess that the insides are not primed at paint, but given a quick base coat spray over.
Could also be overspray too. |
29th Dec 2014 11:00pm |
CatherineF Member Since: 22 Nov 2014 Location: Wiltshire Posts: 762 |
What if Dinitrol stone chip stuff is sprayed up into the arches?
29th Dec 2014 11:02pm |
You can do that, that's what I did before applying Dinitrol.
But I made sure it was absolutely perfectly clean and as dry as you could possibly get it in mid summer first. It does indeed calm down any flying stones in the tyre tread. |
29th Dec 2014 11:05pm |
its just overspray flaking off the plastic
29th Dec 2014 11:06pm |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3747 |
Yep
When i did the underside of the new one, also Dinitroled the inside of the wheelbrows, As said, they all do that, even with a hosepipe ! California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
