Home > 130 > It's started, Longshanks will no longer be a Pick up |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19657 |
Looking good.
25th Dec 2014 1:31pm |
chadjizz Member Since: 25 Apr 2012 Location: sussex Posts: 559 |
that will be a tidy install. nice one.
26th Dec 2014 11:08am |
DiscoStu Member Since: 30 Jun 2007 Location: London/The far north Posts: 253 |
Looking good
Bulkhead holes a good idea - I eed to get a lot of wiring through there, will look at your idea My Disco 'best bits' Defender 110 XS CSW 2013 |
10th Jan 2015 11:31am |
Just a pointer....
If you are making extra holes in your vehicle to run cables through these are in my opinion the best Marine Grade cable glands you can use. Any good chandlery should be able to source them for you. Especially ideal if the cable exit/entry is visible too. Not cheap but what value do you place on quality? http://www.indexmarine.co.uk/cable-glands.html If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
10th Jan 2015 11:39am |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3707 |
Tidy
10th Jan 2015 11:59am |
I tend to use industrial ones that are used in 300 Bar washes - they seem to do the trick My Disco 'best bits'
10th Jan 2015 12:02pm |
Normal cheap skintop plastic ones also do the job too but are not low profile. Depends on the application and what 'type' of finish you want to achieve I suppose. If you go through life with your head in the sand....all people will see is an ar5e!!
10th Jan 2015 12:05pm |
MrFlips Member Since: 27 May 2009 Location: Cardiff Posts: 682 |
He did the same with me, what a @£$%&*%! I love watching this build! Peter 2008 SWB Truck Cab 1952 80" Soft top |
10th Jan 2015 10:22pm |
Cracking on with the wiring for the extra bits and pieces
Click image to enlarge |
12th Jan 2015 1:34pm |
tookaphotoof Member Since: 18 Mar 2013 Location: dordrecht Posts: 1279 |
Oh lord, is this the result of someone stealing your head unit?!!!!
12th Jan 2015 2:13pm |
Oh my...... got more things to fit, will it ever end
Click image to enlarge Last edited by AndrewS on 13th Jan 2015 9:56pm. Edited 1 time in total |
13th Jan 2015 9:37pm |
Go on then, I'll help you out and take them off your hands My Disco 'best bits'
13th Jan 2015 9:40pm |
You need a 130 for these Stu they are 'Man Brakes'
13th Jan 2015 9:57pm |
Man brakes? Try an XJR, they're man brakes! Not adverse to a 130 though, so happy to take that off your hands too Once you've finished the wiring though, bit messy at the mo... My Disco 'best bits'
13th Jan 2015 10:01pm |
