Home > Maintenance & Modifications > Dynamat |
Do a search there's loads and loads of information on it and alternative products. If you go through life with your head in the sand....all people will see is an ar5e!!
19th Dec 2014 3:25pm |
NigelM Member Since: 20 Nov 2014 Location: South Posts: 114 |
I chose not to use Dynamat due to the costs. Did a bit of research and found that to effectively sound insulate anything you need 3 layers:
1. A heavy Dynamat type product to add weight to the panels. Does not need to cover panels entirely 2. 10mm plus of closed cell foam 3. High density vinyl type product on the outside. I used some Butyl Flashing from Wickes as layer 1. A 10mm closed cell foam for layer 2 and relied on the rubber matting for layer 3. I have done the whole of the inside of the TD5 HT apart from the roof. It has made a significant difference to the noise. Can now hold a conversation without shouting on the motorway and listen to the radio. The work has highlighted the noise that comes from the bonnet - this being the loudest area left. I have bought more Butyl Flashing and some Dynamat Hood Liner (I think you need to use the right stuff next to the engine) and will be fitting it over Xmas. It's never going to be a RR but it's getting pretty civilised now. Hope that helps. Nigel |
19th Dec 2014 3:31pm |
Roz Dev Member Since: 09 Dec 2014 Location: East Coast Posts: 72 |
Thanks Nigel
Very informative! sorry K9F, new to the forum, just seen the search function now that you have pointed it out, will use that in future before I post to avoid repeat topics. |
19th Dec 2014 3:36pm |
@ NigelM The roof itself would make a big difference as it's made of very large reasonably flat panels that resonate a lot also it's quite close to your ears.
19th Dec 2014 3:45pm |
Thanks Mk1, might give that a go with the Butyl as well.
19th Dec 2014 3:53pm |
Yeah best to do the Dynamat type product and the closed cell foam as it should get rid of the winter roof condensation that defenders seem to suffer from aswell as stopping vibration noises.
19th Dec 2014 3:57pm |
SGH Member Since: 27 Sep 2010 Location: Hellingly-Sussex Posts: 1527 |
Done all of the inside of my 130
19th Dec 2014 4:15pm |
Skeggy 90 Member Since: 07 Oct 2013 Location: Skeg Vegas Posts: 232 |
I have had my 110 done with Skinz, a very similar product. Bonnet, floor, roof, doors & seat box. It has made an enormous difference. it is a massive job but well worth it. 90 300 TDI SW (sold)
130 TD5 Utility (Foley SV) (sold) 110 TD5 Hardtop (sold) 110 TDCI Utility (sold) 1st Edition Range Rover Sport Supercharged Velar P380 HSE Discovery 1 V8 auto Puma 130 Double Cab (sold) R35 GTR Defender 110 300 TDI CSW (sold) 2010 110 XS Utility |
19th Dec 2014 6:02pm |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 |
Here is my ongoing thread
http://www.defender2.net/forum/topic31184.html My 109 thread my youtube channel |
19th Dec 2014 6:28pm |
Thanks G-mack
Subscribed! |
19th Dec 2014 8:28pm |
mark_d Member Since: 07 Sep 2013 Location: Northern Ireland Posts: 265 |
I've done my doors and the rear tub. Just this evening I've stripped out the side panels and headlining to do a bit more.
The main source of noise is from the engine and gear box. For that reason I'm leaving those areas until last. I've used a lot of dynamat in the past when i competed in Car Audio but I have switched to Silent Coat and I'm happy with the performance. Here are some links to my blog detailing the work. http://defender90xs.blogspot.co.uk/2013/06...age-1.html http://defender90xs.blogspot.co.uk/2013/06...-door.html http://defender90xs.blogspot.co.uk/2013/06...r-tub.html This has made a very noticeable difference to the noise levels. http://defender90xs.blogspot.co.uk/ |
19th Dec 2014 9:35pm |
