Home > Technical > TD5 Clutch slipping
tazmarkuk
England 2000 Defender 110 Td5 HT Chawton White
TD5 Clutch slipping
Hi guys, after some advice, I had a new clutch kit fitted along with a new dual mass flywheel about 14 months/6000 miles ago, the clutch as started slipping but only when you put your foot down and let the revs climb, driving normally has no affect, I can even going up hills in 4th or 5th, I can also stall the motor, I,m looking at adjusting the pedal tomorrow but don't think their is enough adjustment to reduce the slip. If I was to replace the clutch again would you recommend changing the fly wheel again or take a chance, as some say without replacing the flywheel will wreck a new clutch. Bow down Bow down Bow down
What's the difference between a standard and heavy duty clutch beside the price Rolling with laughter
Post #378372 12th Dec 2014 1:04pm
roel
First thing to check:
Does your clutch pedal return to the very top position? If it moves more difficult it might not return completely and this gives the same symptoms.
After you change gear check if you can pull up your clutch pedal with your feet and i'll bet the clutch won't slip anymore.
I have the same problem I just found out. I thought my clutch was on the way out after installing a power box but a few weeks ago I found out that my pedal doesn't return completely and a few days ago I found out that I can use all the power the box gives as long as I pull the clutch pedal up.
So I think I have to lubricate the clutch pedal. Just have to find out how to get to the right point. But first my D3 needs its regular maintenance. Evil or Very Mad Roel
2003 90 Td5 (2009-now)
Post #378404 12th Dec 2014 3:08pm
tazmarkuk
Hi thanks for the info, but yes the pedals returns fully
Post #378406 12th Dec 2014 3:25pm
JWL
There's a common fault that can make a clutch slip especially at higher revs i.e. that point just before the next gear change, 2nd to 3rd, 3rd to 4th etc. This is 99times out of a 100 due to contamination, usually a leaking fuel pressure regulator or the rear of the rocker cover through the half moon portion of the gasket. These symptoms show up in damp weather and with mine I've had it show up for a short time on long journeys. Another source of contamination may be from a faulty rear engine seal.
If there's any sort of oil showing at the back of the engine and over the top of the bell housing, fix the leak and use the motor, it wil 'burn' off eventually or you can squirt brake cleaner or the like into the bell housing to help disperse the contamination.
Clutches do last on Td5's, my 110 has over 170K on the clock, I use it as my daily driver and I use it for everything it was designed for, towing, laning, fairly long journeys etc etc all on the original clutch.
Post #378412 12th Dec 2014 3:53pm
tazmarkuk
The rear oil seal was replaced with the clutch, but will be checking in the morning, i haven't noticed anything dripped onto the drive though. Thanks
Post #378452 12th Dec 2014 6:42pm
Funnily enough, my 110 does the same (although for the first 3000 miles of its life it mistakingly had a 300Tdi slave cylinder fitted and not a Td5 one, which although they look the same, the piston has a 5mm deeper insert on the Td5, so gave the impression of having the clutch "slipped")
I just bought yesterday a valeo kit. I did have the fuel pressure regulator leaking a while back, which I fixed, but I see the rocker cover is weeping a little now.
Job for over christmas... clutch and rocker cover.
Joy.... Big Cry
Post #378502 12th Dec 2014 8:35pm
tazmarkuk
I've just checked for leaks, there are none, this was a Valeo clutch kit with dual mass flywheel, I also fitted a genuine spigot bush as these are a couple of mm longer and heard of others having the squeal return not long after a new pattern item being fitted. Looking to see if adjustment on the pedal will help now.
Post #378508 12th Dec 2014 8:59pm
landy andy
I will agree with the above comments. Mine was the same, but after a while found the FPR to be leaking. Takes very little leak, and mine only leaked when going slow, so when returning the most fuel, other times all good.
Andy
Post #378530 12th Dec 2014 10:06pm
barbel jim
Just wondering roughly how long did it take to burn Off ? The old rocker cover gasket had gone hard, causing it to weep, which was replaced 3 weeks ago. Clutch has just started to slip occasionally. Taken out the wading plug in the bell housing, and although nothing ran out it feels oily on the pinkey i managed to shove in, which came out black. Sprayed some brake cleaner in the hole. Fingers crossed it resolves itself Rolling Eyes
Post #414284 6th Apr 2015 8:30pm
JWL
It doesn't take too long but it can re-appear after some wading or a very wet day especially on long journeys but saying that I didn't spray any degreaser into mine so there is probably residue still in there.
Post #414343 6th Apr 2015 10:17pm
tazmarkuk
Hi guys, update on my original problem of the clutch slipping, Fitted new clutch now, there was no leaks at all, bone dry in the bell housing, the clutch pedal was coming all the way back and there was no more adjustment to be had.
The old clutch looked ok.
I've fitted a new master & slave cylinders even though they weren't leaking and were only about 3 years old. However I had noticed the fluid in the master cylinder was starting to look grey. My thought perhaps it's dragging but I would of thought you would feel it through thee pedal.
I've also fitted a red booster servo, this will be interesting to see how that works. just waiting on a new set of wheels as some low life stole my wheels over the weekend.
Post #414387 7th Apr 2015 7:50am
barbel jim
Got a feeling the rear crank seal is leaking, and timing is just coincidental, but I'll keep spraying the brake cleaner in hope !!!
Post #414506 7th Apr 2015 6:13pm
Daisy90
United Kingdom 2001 Defender 90 Td5 SW Alveston Red
Hi all, how can the clutch / clutch pedal be adjusted please ?
Post #415531 11th Apr 2015 9:42pm
Fatboy Slim
Wales
There is a rectangular plate on top of the clutch pedal box, in the engine bay, next to the brake servo. Take the screws out (6 from memory) and you'll see there is adjustment on the operating rod for the master cylinder. Much easier with 2 people as you can get an assistant to push the pedal down, then you can get the ring end of a 13mm spanner onto the threaded rod to slacken the nut off.
Post #415554 11th Apr 2015 10:16pm
landy andy
Post #415595 12th Apr 2015 4:35am
