Home > Technical > TD5 Clutch slipping |
Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 999 |
That happened to someone I knew - except he put a new clutch in before it happened again and he realised it was the fpr....
On the subject of fluids breaching the bellhousing - I gunk'd and jet washed mine to remove all the grime, and the very next day the clutch started juddering coming off the bite - enough to stall a couple of times. A friend convinced me it was coincidence - but now 2 or 3 weeks later and it appears to have 'burned' off - with the judder gone. I must admit I had thought the bellhousing to block seal was more robust than that ... ? |
12th Apr 2015 9:15am |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1411 |
I think mine is just coincidence now. Been fine the back end of the week towing so hope all is ok. I did change the starter motor solenoid last weekend, and as previously mentioned the rocker cover gasket had leaked prior to being replaced. I did notice some oil run down the bellhousing when I removed the starter motor. Some must have run down internally through the starter motor hole whilst removed. I just sprayed brake cleaner through the wading plug hole on the bottom of the bell housing. The first night loads of black gunk flowed out, but by night 4 it was running pretty clear. I have left the bung out for now Fingers crossed
12th Apr 2015 10:33am |
geobloke Member Since: 06 Nov 2012 Location: Nottinghamshire Posts: 4392 |
In the almighty words of all Land Rover owners everywhere...
...Balls... My clutch is slipping as described in this thread and I have oil flowing down from the rocker cover... Guess I will be bang some brake cleaner and a new gasket... Fingers crossed |
7th Mar 2017 8:56pm |
