Home > Technical > Noisy Puma |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1729 |
Prop shaft joints? Early ones had no grease points IIRC.
Keith |
30th Nov 2014 10:14pm |
Smudger Member Since: 26 Nov 2012 Location: Basingstoke Posts: 36 |
I changed the front for a Bailey Morris extreme a couple years as the original was proper trashed. That was only noisy under load but I'll check them both.
Smudger 08 110 Puma Station Wagon 65 Jaguar XF Sportbrake S 99 Elise 111S Honda XR250 42 Royal Enfield Flying Flea 43 Matchless G3L |
30th Nov 2014 10:19pm |
I've now checked the props, wheel bearings and had the wheels rebalanced. I'm wondering if the hand brake is playing up, possibly stuck on, anyone care to comment?
S 08 110 Puma Station Wagon 65 Jaguar XF Sportbrake S 99 Elise 111S Honda XR250 42 Royal Enfield Flying Flea 43 Matchless G3L |
3rd Dec 2014 8:42pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5430 |
Is common for the handbrake to be poorly adjusted, which then causes noise especially once warm. Take for a drive then feel temp of brake drum.
Andy |
3rd Dec 2014 10:30pm |
hmm, a quick test drive, noise present but cold brake drum. this is annoying now.
3rd Dec 2014 11:11pm |
3rd Dec 2014 11:16pm |
