Home > Tdi > A Real Shocker! Advice Needed. |
Ellisboy Member Since: 13 Oct 2013 Location: Deep South Posts: 539 |
Thanks for the advice everyone! I've ordered a pair of Koni heavy tracks today.
1st Dec 2014 2:29pm |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3707 |
Was your vehicle loaded most of the time and/or used on rough terrain? |
1st Dec 2014 5:16pm |
newhue Member Since: 28 Apr 2014 Location: Brisbane Posts: 351 |
That looks like a a salisbury mount Do you have the flat washer between hanger and rubber? The rubber bush on mine is just a flat disc ( not the moulded P38 ones) placed between two steel washers. Both the same for upper and lower rubbers. I kept tightening until the nut bottoms out on the non threaded shaft. They do squash down a fair bit, but have been on for 70K ilm now with a good amount of articulating use. I want to replace the rubbers as they are two years old now, but all I can seem to find that is quoted to fit a salisbury look nothing like the ones that came with the koni shocks. Instead they are the slightly risen moulded ones for P38s, or front ones which are smaller in diameter. Koni the slacko's have not replied to any emails. My Defender and travels |
2nd Dec 2014 8:02pm |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3755 |
Exactly & well said. The "loads have to go somewhere", which is why I asked what "grade" those bushes were,..still don't know,...were they the hard ones, soft ones or what? Pickles. |
2nd Dec 2014 10:17pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2557 |
It's a Rover axle. Yep the flat washers are fitted against the axle bracket.
A while back I found a website selling spare bush sets: http://www.larkspeed.com/index.pl?c=KONISPARES&s=category |
2nd Dec 2014 10:18pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19611 |
Pickles - The red are the hardest grade, I have them on mine.
I cannot see any real argument for or against either type, both fail, both fail at varying mileage. Yes, Polybushes are stiffer and genuine softer, with genuine not transmitting vibration so much to other components. However, genuine don't last long and wear fairly quick and degrade with common antitrust treatments. Rust plays a part in wear also and shocks are not something that you can change every five minutes without binning the shocks sooner or later. On the shocks I previously had which were genuine with genuine bushes, the shocks were absolutely fine, but the bushes shot. This in turn mean it was so loose the bolt through the middle could move around a lot, again causing excessive wear on a big scale. Obviously I sorted this quick, but the shocks were seized especially the fronts and the only way to remove was to cut off. So I had to get rid of perfectly good shocks thanks to genuine bushes being knackered at about 38k. |
2nd Dec 2014 10:35pm |
Nice, thank you My Defender and travels |
3rd Dec 2014 8:35am |
Thanks. I haven't had any experience with Defender suspensions, but a fair bit with V8 Sedan stuff in Aus. Many shy away from stiffer bushing because yes, they do maintain alignment settings much better, but because they are "stiff" with less "give" mors strain/vibration/shock etc is transferred to the mounting points which can sometimes fail. There has to be a compromise somewhere I suppose. Regards, Pickles. |
3rd Dec 2014 9:14am |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2086 |
A common cause of breaking the bottom pin on rear shocks is having the dished washer the wrong way round. The dish should be away from the bush on the bottom of the lowest bush and the top of the bush above the axle bracket. If they are the other way round they can touch each other as the bush compresses.
I've not broken a pin since I learned this Mo The Land Rover 90 - Many are called, few are chosen. |
20th Jan 2015 12:09pm |
steventheplumber Member Since: 29 Apr 2014 Location: Lincolnshire Posts: 767 |
thankyou Mo, am working on my rear axle at the moment so will follow your adivce
Click image to enlarge |
21st Jan 2015 7:59pm |
