Home > Td5 > TD5 engine bay noise |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 |
vid is private!! My 109 thread
my youtube channel |
25th Nov 2014 5:15pm |
JJ440 Member Since: 08 Nov 2013 Location: Geneva Posts: 51 |
Fixed!
25th Nov 2014 5:38pm |
hmm hard to tell, could be crank damper, not cheap for genuine replacement. some one with more experience should come along soon My 109 thread
25th Nov 2014 5:52pm |
Nidge Member Since: 27 Jan 2008 Location: Kildare Ireland Posts: 809 |
Hard to tell.....but to me engine sounds fine internally , there is no belt to worry about as TD5 is chain driven.
Sounds external... aircon pulley I bet or altenator bearing or water pump N. |
25th Nov 2014 7:52pm |
mturri Member Since: 13 Jul 2010 Location: Patagonia Posts: 29 |
Been through this before.
Initially thought it was the viscous fan bearing, but after removing belt noise was gone. Borrowed a mechanic’s stethoscope and scoped the prime suspects (alternator, PAS pump, AC comp, idler pulley, etc.). The belt tensioner sounded a bit too raspy, and whilst not entirely convinced changed it out for a new unit (p/n ERR6951). Screeching gone. Cheers Matt |
27th Nov 2014 10:46pm |
Good advice, could very well be the tensioner. Seems the noise comes from the upper part of the engine, so that coincides with the tensioner.
I've read the belt can be a pain to get on, will let you know how I get on and if I it was indeed the culprit. Is it worth going with a genuine replacement or am I ok with aftermarket? (£17 vs £48 ) |
28th Nov 2014 5:50pm |
Tommo Member Since: 19 Dec 2013 Location: Leicestershire Posts: 830 |
Genuine all the way. When I did my belt I did it from underneath with my mate holding the spring pully as I couldn't do it without his help. You could take to viscous fan off which makes access easier!!
28th Nov 2014 9:27pm |
Carlosbeldia Member Since: 13 Oct 2013 Location: Cartagena Posts: 43 |
That sound is or tensioner or A/C Pulley....
1st Dec 2014 4:03pm |
I see I forgot to get back too you... cliffhanger.
It was indeed the tensioner. For others; best not drive the car a lot before you fix it, the tensioner will freeze up and leave you stranded sooner or later. |
11th Feb 2015 10:31pm |
