Home > Technical > Grease guns |
cornish rattler Member Since: 31 Aug 2013 Location: Manchester Posts: 642 |
You could try changing the nozzle on the grease gun as some nozzles don't always work and some do, i find with my grease gun it will grease the rear prop no problem but when trying to grease up the front prop the nozzle touches the UJ before it fits onto the nipples so have to resort to removing the prop to grease it Graham
1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) |
15th Oct 2014 12:26am |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
I use a cheap £10 Silverline grease gun,goes on easy enough, a bit fiddly detaching it but has a good seal and doesn't leak. Pov.spec,ftw. 2006, 110,TD5.
15th Oct 2014 12:27am |
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3471 |
I have several grease guns but my favourite for greasing prop UJ's is the one which I have fitted with a flexible shaft and ground two flats on opposing sides of the nozzle itself. Steve.
15th Oct 2014 8:01am |
Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 999 |
The state of the UJ's makes a difference - if the are solid with hard grease - then with the new stuff taking the line of least resistance, that may be the seal on the connector.
15th Oct 2014 8:28am |
x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327 |
This is the one I use that is perfect on the UJs. The flexible hose means I can get on the nipples and the fitment is tight enough not to leak.
http://www.ebay.co.uk/itm/Hilka-Pistol-gri...2a2ffdf1df Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
15th Oct 2014 1:02pm |
kipperthedog Member Since: 27 Jun 2013 Location: Down South Posts: 403 |
Warming the grease in the Uj with a hairdryer/heatgun can help with the displacement of any old grease.
15th Oct 2014 6:53pm |
amondeggs Member Since: 06 Mar 2011 Location: Telford Posts: 452 |
Thanks to all for the comments
The UJ's are an area I don't neglect, I tend to remove props at least once a year sometimes twice. If I find any play then I change the UJ's. I always use gkn one as the quality is good. As explained the only issue I have is regreasing so that I get grease coming through each of the bearing sets. X Isle thank for the tip I think I will purchase one of those guns At least I know that it fits and does the job Thanks again |
15th Oct 2014 7:49pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2557 |
This. I had similar issues the first time I tried to grease props, consulted a friend with many years Land Rover experience and his advice was to grind the tip of the gun down slightly. Did that and it's been fine ever since, works a treat |
15th Oct 2014 8:06pm |
cheap guns have cheap ends
Wanner are a good make , used in aircraft industry |
15th Oct 2014 8:08pm |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
I use an old grease gun probably my granddad has used it already. The strange thing is that you just push it against the nipple. If you the continue pushing the body off the grease gun in the direction off the nipple the shaft is pushed in the body and the grease into the nipple and it hardly leaks any grease.
Because it doesn't have to go over the nipple the head is small. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
16th Oct 2014 8:53pm |
