Home > Maintenance & Modifications > Anyone know what should be in here
Shutts
United Kingdom 1995 Defender 90 300 Tdi SW Arles Blue
Anyone know what this connector should have in it?
The headlights have been replaced with HID units and the link cable works the high beam. I assume the cable is in the right place as it fell out when removing the mobile phone kit.
Many thanks in advance for our help.
Shutts |____000_
[l_|__\___\,___
l--___--_[O==O]
()_)' '()_)-----()_)
2005 D3 SE
1998 Disco 300tdi - slow play thing
1995 Defender 300tdi - Winching play thing
Aprilia RSV 1000 - fast play thing
Honda CR250 - noisy play thing
Essex Land Rover Club member
Andy's Landy's - http://www.andys-landys.blogspot.com
Suspension checking workbook - http://www.disco3.co.uk/gallery/albums/use...k_v002.zip
Post #362496 5th Oct 2014 11:35pm
mk1collector
Probably a dim dip relay that's been bypassed
Post #362499 5th Oct 2014 11:41pm
JWL
Isn't that the bypass to get shot of 'Dim Dip' headlights.
Post #362500 5th Oct 2014 11:42pm
Shutts
Thanks guys, seems to make sense. With the loop removed only the dip beam works, and once the loop is in place the high beam works off the switch. I expect this was done at the time the HID lights were installed and it overcome an issue with the relay.
Do the HIDs use less power, therefore, not having the relay will not do any damage to the wiring, or should the relay be put back in?
Shutts |____000_
[l_|__\___\,___
l--___--_[O==O]
2005 D3 SE
Post #362520 6th Oct 2014 7:59am
munch90
yes hid's use less power , but not really legal to fit in a lamp designed for a standard filament bulb
Post #362521 6th Oct 2014 8:04am
K9F
Munch is correct..... Thumbs Up
http://www.defender2.net/forum/topic30217.html?highlight=hids If you go through life with your head in the sand....all people will see is an ar5e!!
Post #362536 6th Oct 2014 9:08am
Shutts
Will need to check the lamp housing to see if its standard or not then decide what to do next. |____000_
[l_|__\___\,___
l--___--_[O==O]
2005 D3 SE
Post #362546 6th Oct 2014 10:12am
munch90
the lamp housing will be standard as they don't make a 7 inch hid headlight unit
choice is really back to standard bulbs
relay standard bulb for bit better output and better bulbs like nightbreakers etc
fit e marked led headlights
Post #362547 6th Oct 2014 10:14am
