Home > Maintenance & Modifications > Anyone know what should be in here |
Shutts Member Since: 10 Aug 2014 Location: Tiptree Posts: 52 |
Anyone know what this connector should have in it?
Click image to enlarge The headlights have been replaced with HID units and the link cable works the high beam. I assume the cable is in the right place as it fell out when removing the mobile phone kit. Many thanks in advance for our help. Shutts |____000_ [l_|__\___\,___ l--___--_[O==O] ()_)' '()_)-----()_) 2005 D3 SE 1998 Disco 300tdi - slow play thing 1995 Defender 300tdi - Winching play thing Aprilia RSV 1000 - fast play thing Honda CR250 - noisy play thing Essex Land Rover Club member ------- Andy's Landy's - http://www.andys-landys.blogspot.com Suspension checking workbook - http://www.disco3.co.uk/gallery/albums/use...k_v002.zip |
5th Oct 2014 11:35pm |
Probably a dim dip relay that's been bypassed
5th Oct 2014 11:41pm |
Isn't that the bypass to get shot of 'Dim Dip' headlights.
5th Oct 2014 11:42pm |
Thanks guys, seems to make sense. With the loop removed only the dip beam works, and once the loop is in place the high beam works off the switch. I expect this was done at the time the HID lights were installed and it overcome an issue with the relay.
Do the HIDs use less power, therefore, not having the relay will not do any damage to the wiring, or should the relay be put back in? Shutts |____000_ [l_|__\___\,___ l--___--_[O==O] ()_)' '()_)-----()_) 2005 D3 SE 1998 Disco 300tdi - slow play thing 1995 Defender 300tdi - Winching play thing Aprilia RSV 1000 - fast play thing Honda CR250 - noisy play thing Essex Land Rover Club member ------- Andy's Landy's - http://www.andys-landys.blogspot.com Suspension checking workbook - http://www.disco3.co.uk/gallery/albums/use...k_v002.zip |
6th Oct 2014 7:59am |
yes hid's use less power , but not really legal to fit in a lamp designed for a standard filament bulb
6th Oct 2014 8:04am |
Munch is correct.....
http://www.defender2.net/forum/topic30217.html?highlight=hids If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
6th Oct 2014 9:08am |
Will need to check the lamp housing to see if its standard or not then decide what to do next. |____000_
6th Oct 2014 10:12am |
