Home > Td5 > So has anyone failed their MOT with a de-cat'd TD5 yet?
Page 2 of 3 <123>
K9F
Cheap as chips and available in abundance for a TD5 one. Try sourcing one for a Puma, was easier and cheaper to design and fabricate my own. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #358317 16th Sep 2014 10:24pm
roel
If somebody need a front pipe with Cat, he can come to me and change out my front cat pipe with a non cat pipe. Mr. Green Roel
2003 90 Td5 (2009-now)
Post #358347 17th Sep 2014 7:39am
Will.I.AM
United Kingdom 2005 Defender 130 Td5 HCPU Kaikoura Stone
i have a 56 plate, with a de-cat and cherry bomb, and it went straight through no questions, i think to be honest its down to the MOT station, if they know the vehicle is safe and they like you, it normally passes! Thumbs Up
Post #358908 19th Sep 2014 1:35pm
K9F
Wonder if the insurers would be so obliging in the event of an investigative claim? Any excuse normally?
Whistle If you go through life with your head in the sand....all people will see is an ar5e!!
Post #358910 19th Sep 2014 1:48pm
Will.I.AM
i tend to think about it. Rolling Eyes
Post #358911 19th Sep 2014 1:51pm
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
I'm thinking of putting my cat back on just to be on the right side of the law, plus I'm sure it'd make the exhaust note slightly quieter, has anybody put the cat pipe back on? Even if it was just to get an MOT?
I'm wondering what difference in power it'd make overall, is it going to be noticeable or negligible?
Post #360047 25th Sep 2014 6:55am
K9F
It'll be the opposite effect of when you took it off! Can you not remember? Rolling with laughter Rolling with laughter
I can still remember the significant difference it made when my cat was initially removed. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #360062 25th Sep 2014 10:02am
Stue5
Italy 2005 Defender 110 Td5 USW Alpine White
Ex environment agency vehicle came with no cat Smile Td5 2005, egr removed ect. Range Rover p38 4.6 99 lpg(gone Sad )
Post #360064 25th Sep 2014 10:25am
Stue5
sorry forgot to say it passed the mot last month Sheep Sheep Sheep Sheep Range Rover p38 4.6 99 lpg(gone Sad )
Post #360065 25th Sep 2014 10:26am
Lambley
Laughing No I can't remember to be honest! I do know it made a bit more noise.
I'm Going to see Gary at Alive and get him to check everything's running properly as when it was MOT'd the first reading was high, I just want him to check the map and diagnostics over and I'm tempted to put the cat back on beforehand, maybe even tweek the map down a bit
Post #360067 25th Sep 2014 11:18am
K9F
Another option that I've just this minute posted on a sister thread before you refit perhaps? You could then fit and forget....
ZeDefender wrote:
Those with weak stomachs, look away now...
10 minutes and a lot of dust - hopefully not asbestos Shocked
If I can, I'll be testing emissions before and after EGR blanking and cat removal - can probably squeeze some school project out of it for my lazy son Thumbs Up
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  If you go through life with your head in the sand....all people will see is an ar5e!!
Post #360071 25th Sep 2014 11:30am
Lambley
I did think of doing this but it's not as easy on the earlier models, the cat's not at the end it's more towards the middle so it'd probably mean cutting, removing and re-welding it Sad
Post #360075 25th Sep 2014 12:16pm
landy andy
Does it not dissolve with petrol? Something in the back of my memory when they first came out that if you kept cranking a petrol engine cat would be damaged with the petrol?
Post #360083 25th Sep 2014 2:42pm
K9F
Embarassed Sorry Lambley TD5 thread. Embarassed You could get something fabricated in stainless if you've a stainless decat pipe already. You'd obviously have to get the pipe cut and subsequebntly rewelded to fit but it shouldn't be an issue.
My Puma now has a cat fitted in the same place as a TD5's. Thumbs Up
Post #360090 25th Sep 2014 3:41pm
munch90
that was if you cranked a petrol over the petrol would soak in to cat then when it started it could burn in side and the heat could melt the core , not dissolve it
Post #360098 25th Sep 2014 4:34pm
Page 2 of 3 <123>
