Home > My Defender > Replacement Battery
Buz
United Kingdom 1987 Defender 90 200 Tdi HT Barolo Black
Replacement Battery
Looks like my battery is in need of an upgrade.
Its only 650CCA and is starting to fail now so guess i'll replace it before the cold weather starts. It can be parked up from one weekend to the next (sometimes longer). I also have a conditioner for my bike so will stick that on during really cold weather when its stood for a while.
Thing is, i'm not sure what to get. The one in there isn't standard, its just been stuck in the battery box and allowed to 'float around' (I've fixed it down since I had it)
The engine is a 200tdi disco, sitting in a 1987 Defender 90.
There is nothing drastic to draw current at the moment but I may well ne fitting a winch in the future. Also thinking of upgrading to a dual battery at a later date so ideally want something that I can add to.
I've heard 95AH and a 850CCA as a minimum, is this about right? and what is the best make?
A couple of times now its been the solitary clicking when trying to start it, a quick boost with jump leads or charger and it fires up ok. I will be checking current draw to ensure there isn't a fault and no, i've not checked battery voltage or alternator output yet. I feel the battery is past its best and needs changing anyway.
So, whats the collectives recommendations for batteries?
Post #355191 2nd Sep 2014 4:50pm
excossack
I think (without looking at the battery) but, I'm pretty sure I got this spec for my TD5
http://www.ebay.co.uk/itm/Varta-Silver-I1-...3f3b29ce4b 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #355199 2nd Sep 2014 6:28pm
ericvv
I think tatra805 gave the best advise as to Defender batteries. In short, unless you plan to use your truck in extreme conditions, Land Rover's choice for the Puma of a Varta Professional Deep Cycle Marine Leisure , 90Ah/800CCA battery is just excellent. My own original battery is now 6 years old and still going strong- Thumbs Up
Read tatra's well educated opinion Bow down in below thread.
http://www.defender2.net/forum/topic16605.html You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #355205 2nd Sep 2014 7:19pm
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
I fitted a Bosch S5 to my TD5...got it from Costco with 5 year warranty. 110ah and around 900cca.
http://www.carparts4less.co.uk/cp4l/p/////...p;cc5_1026
Has been great.
Simon
Post #355206 2nd Sep 2014 7:21pm
