Home > Puma (Tdci) > horn plus 'flasher' |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
Sounds like a faulty switch in the steering column to me. Suspicious that there's clearly nothing wrong with the lights wiring - just the stalk. One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition |
6th Apr 2010 9:52pm |
MrFlips Member Since: 27 May 2009 Location: Cardiff Posts: 682 |
The flashers and the horn run from the same fuse so that's worth a look. The fuse you want is in the secondary fuse box under your seat, and is labelled F3 here:
Peter 2008 SWB Truck Cab 1952 80" Soft top |
wyvern Member Since: 14 Dec 2009 Location: Cornwall Posts: 2074 |
it's probaboly the stalk - had the same thing happen to me on our TDI, TD5, and on the Puma.. .. Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
7th Apr 2010 6:29am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19620 |
right i'll have a check of the fuse first off then maybe move onto the stalk. Would this fail an MOT? also i think that a new indicator stalk is plug and play? other than removing and refitting
7th Apr 2010 12:56pm |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 |
If you can't beep yor horn it will be a fail. As you have put....best check the fuse and then the stalk, and it will be a simple plug off and on Glyn |
7th Apr 2010 12:59pm |
checked fusebox today seeing as i thought about it thank-you for the fuse box diagram that really helped yes the correct F3 fuse is blow i should imagine it's because the spot lights i have were wired up wrong when i got it and thats done it as i replaced them. problem is i don't have a 20A fuse just now
9th Apr 2010 12:09pm |
replaced fuse with same rating replacement. and all is well every thing is working now thank you to all that helped
9th Apr 2010 4:08pm |
