Home > Tdi > 300Tdi gearbox crossmember rust |
Nice write up An engine to TDi for!
"Land Rover- Proudly turning drivers into mechanics since 1948" |
1st Sep 2013 8:41am |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 |
Similar things happen behind the rear shock upper mounts too, worth a look there too. 2005 Td5 90 XS
Steve |
1st Sep 2013 5:18pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2560 |
Yep, I guarantee you every Defender on the road with a gearbox crossmember that attaches like that (the 200Tdi style one on a 110 I took apart was the same) which hasn't had it sorted will be the same underneath. MOT man can't fail it for something he can't see.
Lou is correct re. the shock mounts. I had this issue with my 90 (see here). Haven't dared take the gearbox crossmember off yet! |
1st Sep 2013 5:40pm |
Skye_Rover Member Since: 30 Aug 2013 Location: Skye Posts: 85 |
AFAIK, the shock mounts on mine are OK. I had a go at rust-proofing the rear of the chassis in 2004 (the rear crossmember was solid but looking like it was about to rust) with a combination of rust-converter, POR15, and underbody Waxoyl sprayed everywhere aft of the crossmember near the transmission brake. Now you have got me worried, though.....
Tomorrow sees the refit of the bits around the gearboxes, and putting the front-end back together (timing belt changed), plus a few "extras" like sorting out the winch solenoid (renew) in the F/N/S wing, maybe a few suspension polybushes, offer-up the body-stiffeners (AKA rock sliders) to keep the SW body from self-destructing at the C-post every time I hit a pothole (which is every 10yards on Skye). And now an inspection of the rear shock mounting areas, which I did paint and treat behind in 2004, but sage advice is sage advice! Having got the gearbox crossmember fitted this afternoon, I was surprised how easily it slid up into place between the chassis rails. I reckon I added 0.5mm of steel to the rail thickness on both sides, yet the whole thing seemed quite loose. Perhaps the jacking of the rails to get the xmember out was not all elastic deflection Roads? Where we're going, we don't need roads. |
1st Sep 2013 11:12pm |
All clear on the rear shock mounts. A bit scabby around the paintwork, but the Waxoyl seems to be holding the corrosion at bay. Definitely needs to go on the maintenance schedule, along with the bulk of the chassis rails. I did a fair bit of topping-up the wax around the vehicle this afternoon, but clearly it isn't going to last forever. The best policy, if I had time last year, would have been to strip, convert the rust, and paint in a decent chassis paint. The wax has not really got a good hold on the exterior of the rails, so tends to flake back off in time.
I had a good session on the radiator pack, which gets a regular dose of wax, as this seems prone to rotting around the outside framework. Having said that, the radiator matrix is going to be the first thing to require a change; common to most modern radiators, the fins are just falling off the flues with corrosion after 5 years, so it will need consideration for replacement in the Spring. Roads? Where we're going, we don't need roads. |
2nd Sep 2013 11:40pm |
WarPig Member Since: 05 Dec 2009 Location: Sheffield Posts: 1748 |
Richards Chassis sell galvanised gear box cross members if that needs replacing.
3rd Sep 2013 12:57am |
The gearbox xmember was a bit scabby on the tabs where they had touched the chassis, but having cleaned and painted them, then smothered the whole lot in grease, I don't think there will be a problem.
One day, but not now, I want to go over to a decent galvanised chassis from someone like Richards. I did a re-chassis on my 109" back in 1990, that was one of the first few Steve Walker chassis in heavy duty steel, leaf spring mounts, dripping with heavy zinc. He drove it down to me personally, having got a trailer load of these things to deliver in Dec_90, pulling with an SD1 2.4Diesel, and the snow just starting to fall at 10:00pm as he set off to deliver the rest from the Midlands. Now, that's what I call dedication! Roads? Where we're going, we don't need roads. |
3rd Sep 2013 3:24pm |
I've got one of those, sitting between the chassis rails, on my Richards galvanised chassis An engine to TDi for! "Land Rover- Proudly turning drivers into mechanics since 1948" |
3rd Sep 2013 5:49pm |
The test-drive this evening has proven the Defender to be driving and handling so much better than of recent. It's back to the way it used to be a couple of years ago. Allowing for the improved driveability from the powertrain, I'm still a bit perplexed by the way that the suspension seems to have tightened-up; so far, none of the bushes has been replaced (as scheduled for yesterday), yet the vehicle seems to be handling far better. I'm wondering if this is just a bit of imagination, or has the chassis welding improved the stiffness under cornering? Thinking laterally from that, was the clutch judder partly down to flex in the gearbox mounting at the chassis itself? Seems a bit unlikely, but the sea-change in the behaviour of this 110" CSW is unexplainable just from the clutch change and new gearbox rubbers (all previous components were in good order, loads of life left in them, and comparable on spring-rates with the new bits going in). Roads? Where we're going, we don't need roads.
4th Sep 2013 12:07am |
