Home > In Car Electronics > How do I remove Carling switch connector? |
ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328 |
from the other side slide a thin metal blade between the plastic & brass connector then pull from the other side theres a tiny brass locate lug there
1st Aug 2013 8:07am |
I haven't got these switch connectors on mine An engine to TDi for!
"Land Rover- Proudly turning drivers into mechanics since 1948" |
1st Aug 2013 8:28am |
TheWarden Member Since: 25 Feb 2013 Location: Southampton Posts: 179 |
That'll be one of those relay type holders for a carling switch. From the other side you should be able to slide a thin blade screwdriver or something similar down the side of the connector to release the little clip that holds it in place then, at the same time pull it out from the back 2013 Aintree Green 110 Station Wagon SX
1st Aug 2013 8:34am |
WarPig Member Since: 05 Dec 2009 Location: Sheffield Posts: 1748 |
Done it. Thanks guys
The +ve wire was touching the other connectors which I think is the cause of some strange problems I encountered yesterday, posted here.... http://www.defender2.net/forum/topic22153.html |
1st Aug 2013 10:18am |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6676 |
We have them on our website as do Mobile Centre and MUD http://www.farrowsclassics.co.uk/Carling-Switches----6-95.html 99p each |
1st Aug 2013 10:23am |
It's just an additional block which allows you to easily unplug the switch in one go, rather than having to unplug each individual wire. The wires go into the block, and the block clips onto the back of the switch. |
1st Aug 2013 10:43am |
