Home > Technical > Wiper Help Pls
sweatysock
United Kingdom 2007 Defender 110 Puma 2.4 CSW Indus Silver
Wiper Help Pls
Hi my wipers have just stopped moving. I can hear the mechanism working but the wipers are not moving. It is a TD5, help appreciated Sweatysock
110 CSW TDCI (Puma) 2007
Post #244289 17th Jun 2013 1:14pm
WarPig
Im being a bit hypocritical as mine have suddenly packed in as well. My fuse is blowing everytime I turn on the ignition. http://www.defender2.net/forum/topic21168.html
First easy check is the fuse. Then..
Faulty relay?
Park switch on wiper motor?
Wiper dashboard stalk/lever/switch?
Wiper spindles seized (the bit that protrudes through the bulkhead which the wiper arm fastens to?
Wiper motor seized?
Also, check to see if the spindles on the outside of the car that the wiper arms attach to are moving. Over time the spines inside the wiper arm fixing point can wear, so the spindles rotates but the arms don't move. This would mean that you need new wiper arms, but usually only one would wear, not both at the same time.
Post #244295 17th Jun 2013 1:21pm
mk1collector
Mine did this and it turned out to be one of the wheel boxes that the wiper arm bolts to which had seized. I decided to replace the motor and both wheel boxes for brand new genuine ones and the difference was amazing! Well worth the £150 ish from the main dealers as the wipers now work like a normal car when they were really slow before.
Post #244297 17th Jun 2013 1:25pm
sweatysock
lovely, thanks folks, i am on it Sweatysock
Post #244308 17th Jun 2013 1:39pm
WarPig
Wiper wheel box/spindle..
Post #244313 17th Jun 2013 2:45pm
mk1collector wrote:
... as the wipers now work like a normal car when they were really slow before.
A clean and grease usually has the same effect!
Post #244339 17th Jun 2013 4:09pm
