![]() | Home > Technical > Wiper Help Pls |
WarPig Member Since: 05 Dec 2009 Location: Sheffield Posts: 1748 ![]() ![]() ![]() |
Im being a bit hypocritical as mine have suddenly packed in as well. My fuse is blowing everytime I turn on the ignition. http://www.defender2.net/forum/topic21168.html
First easy check is the fuse. Then.. Faulty relay? Park switch on wiper motor? Wiper dashboard stalk/lever/switch? Wiper spindles seized (the bit that protrudes through the bulkhead which the wiper arm fastens to? Wiper motor seized? Also, check to see if the spindles on the outside of the car that the wiper arms attach to are moving. Over time the spines inside the wiper arm fixing point can wear, so the spindles rotates but the arms don't move. This would mean that you need new wiper arms, but usually only one would wear, not both at the same time. |
mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6769 ![]() ![]() ![]() |
Mine did this and it turned out to be one of the wheel boxes that the wiper arm bolts to which had seized. I decided to replace the motor and both wheel boxes for brand new genuine ones and the difference was amazing! Well worth the £150 ish from the main dealers as the wipers now work like a normal car when they were really slow before.
sweatysock Member Since: 17 Jul 2011 Location: Warwickshire Posts: 283 ![]() ![]() ![]() |
lovely, thanks folks, i am on it Sweatysock
------------- 110 CSW TDCI (Puma) 2007 |
Wiper wheel box/spindle..
![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16983 ![]() ![]() ![]() |
A clean and grease usually has the same effect! |
