Home > Puma (Tdci) > Alarm/interiors. |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
Have a look at fuse 30, 10amp under the steering column. Also check the grey plug connection in the 10AS for corrosion, and since you have it disconnected spray an electrical contact cleaner into the plug and 10AS ends before reconnecting. Below are the grey plug pin connections and the wiring diagrams for the interior lights and switch sensors. You can test the switch sensors are working by using a DMM, set in the 12v dc range and also coat the contacts in contact cleaner before reconnecting.
Click image to enlarge Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
29th Jan 2013 6:17pm |
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 |
No interior lights working at all both bulbs OK. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
29th Jan 2013 6:51pm |
Scoured the internet but i have resorted to the famous Land Rover fault finder manual. http://1.2.3.11/bmi/pixweluv.com/files/fun...men_01.jpg 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
31st Jan 2013 3:04am |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2012 |
Red-Dot:
Your post at 2.04am!....so you can't sleep then?.....worrying about your Land Rover?! |
31st Jan 2013 9:48am |
Land Rover ownership has its many benifits?? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
31st Jan 2013 11:14am |
Done the AS10 plugs and still the same although the interior light flickered once. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
31st Jan 2013 2:42pm |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 |
Have you checked the bonnet switch LANDYWATCH
Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
31st Jan 2013 5:19pm |
Checked the continuity of the bonnet switch and it has continuity and is operating OK. Multiplug clean and dry. Alarm is now beeping twice every 15 minutes..... 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
31st Jan 2013 6:18pm |
This is driving me bonkers now... Alarm occasionaly sets without the horn but it also sometimes goes off full time. Interior lights sometimes flicker when the switch is in the ON position. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
9th Feb 2013 9:33am |
Liberace Member Since: 13 Jun 2012 Location: Perugia Posts: 18 |
Had this happen to my 2012 the first week of ownership. The dealer found the passanger door switch was not being depressed all the way when the door was shut. The switch itself was good just not enough displacement to the plunger when the door was closed. Symptoms included flickering dome light, especially on bumps. All he had to do was screw the adjuster out a few turns until there was a positive disconnect when the door was shut. Hope it is that simple for you,
ciao James |
11th Feb 2013 3:46pm |
Had the interior door switches out and cleaned and they are working as they should be. Cant figure out why the interiors are not even working in the ON position.
No adjustment on my door switches but are all opening fully. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS.. |
11th Feb 2013 6:25pm |
Go back to basics. Is there a live and earth at the lights, if not is there a live and earth at the pin switches (check continuity between bulb and switch) if nothing at switch check live and earth at fuse then continuity between fuse and switch and so on and so on. Something is going to be amiss somewhere along the line.
11th Feb 2013 7:05pm |
