Home > In Car Electronics > My radio has become a free spirit.....
strang
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Galway Green
I should have had this looked at whilst still under warranty I guess, but the radio in my Puma constanly keeps reverting to a news channel from either Radio One or a CD - I thought it was because I had the 'traffic announcement' option selected, but now without that it still keeps changing channels?
Any ideas - apart from the obvious which is 'drop testing' it from a great height! Euro-Leafing to infinity and beyond.....
Post #197755 31st Dec 2012 1:50pm
Could be worth getting a can of spray contact cleaner, douse the buttons with it and repeatedy push them lots of times, see if it cleans them up... you may have a sticking button?
Post #197757 31st Dec 2012 1:54pm
GUM97
My dad had the same problem, and cured it by holding the traffic button down for a while, rather than just pressing it. The button was a bit tempremental Confused An engine to TDi for!
Post #197759 31st Dec 2012 1:56pm
Try disconnecting it completely and then re-connecting it up(after 20mins or so) so that you have to enter the security code in. This might re-start it and clear any errors messing it up. Failing that if you have traffic updates off I can't think of much you can do. Except for perhaps upgrading to an aftermarket unit.. If you wanted just CD and radio from one a good premium band head unit would only cost you around 50 - 70 and would be plug and play. Not sure what an OE LR radio would cost probably 100 + at least. Diesel$ Live$ Matter. ⛽️🛢️👨‍🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
Post #197760 31st Dec 2012 1:56pm
VeeTee
Netherlands
On most models with RDS (Radio Data System) one can select a favorite PTY code (Program Type). May be you selected (by accident) the "News" PTY code ? Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #197764 31st Dec 2012 2:02pm
JWL
Instead of a total disconnect is there not a reset button, I only ever delve into the el-cheapo end of the market for ICE but there has allways been a reset button often just a small hole under a removable fascia into which I poke a cocktail stick(non conductive in case it's the wrong hole Whistle )
Post #197769 31st Dec 2012 2:08pm
That's true. Trouble is some do some don't. I can't remember if mine does or not. Whistle Saying that it's never played up to need it gods honest truth. Diesel$ Live$ Matter. ⛽️🛢️👨‍🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
Post #197800 31st Dec 2012 3:29pm
jerseyman
Mine randomly changes channels, the only solution I have found so far is to switch it off
Post #197809 31st Dec 2012 3:48pm
Could well be due to poor reception. I find I don't use the radio much for that reason. Could do with a booster really but personally I don't feel it worth the effort. Diesel$ Live$ Matter. ⛽️🛢️👨‍🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
Post #197822 31st Dec 2012 4:29pm
strang
Thanks for the suggestions - a good few ideas there... Euro-Leafing to infinity and beyond.....
Post #198210 1st Jan 2013 8:09pm
strang
Well it was the 'PTY' option, selected by holding the info button in for a while, and removed the same way. I read the instruction book, and all became clear...... Embarassed Euro-Leafing to infinity and beyond.....
Post #205202 25th Jan 2013 2:13pm
