Home > Puma (Tdci) > Central Fixed Air Vents |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2605 |
Yeah, on a long trip it does freeze your arm. But I am used to it now -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
26th Nov 2012 11:01am |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6676 |
You could blank them off internally quite easily and just rely on the round ones as a suggestion
26th Nov 2012 11:04am |
Wouldn't that lead to condensation accumulating inside the dash and possibly leak onto wires/stuff and cause a short? -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
26th Nov 2012 11:14am |
lrmaniac Member Since: 04 Feb 2010 Location: Lisboa Posts: 762 |
Now that would be a nice mod...
Nice challenge to the sponsors and inventers out there! Those of you who have made dash mods, could try and get a solution/fix for that ? If someone could get an OEM look a like fix I'd buy! Regards Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
26th Nov 2012 11:39am |
AlpenAndes Member Since: 20 May 2011 Location: Currently Chile Posts: 128 |
I just used some tape to close the vents behind the dash and nothing is blowing, nothing is leaking. Of course someone may also invent a cap to close it nicely, but who gets a look at it?
26th Nov 2012 5:02pm |
Gwily Member Since: 02 Oct 2011 Location: Cape Town Posts: 13 |
Yeah I could easily close it, I guess I was hoping for a more sophisticated solution that somebody had already invented.
I am just surprised that none of the guys that make 1001 things to modify Defenders have not made anything for this one yet Defender 110 "Huberta" |
26th Nov 2012 5:15pm |
Closing the vents it's not an option for me... It freezes my shoulder in the summer but I believe the vents are needed...the round ones only are not enough in my opinion... Regards
26th Nov 2012 5:17pm |
Agree it blows straight at my right arm (but then we here do drive on the right side of the road , but my experience is with the fan on 1, and with the two controllable vents also open and blowing sideways upward, the flow from those center vents gets bearable. Don't think there is much more that can be done to this.
I am not really bothered, because I very rarely use the airco even in summer, most of the time I use the "Mexican airco" that comes standard with the Defender. You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
26th Nov 2012 6:08pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2271 |
Those are there for the rear passengers. Puma 110" SW
26th Nov 2012 9:28pm |
Which would be fine if it just blew on them! But as previously mentioned it needs all the vents to adequatly cool down the vehicle, especially when the outside temps start to soar! Come on clever engineering companies, If you build it they will come Defender 110 "Huberta" |
27th Nov 2012 12:47pm |
I'm the only one in the UK to reply to this so we obviously don't have a problem 'cooling' in this country !
27th Nov 2012 12:50pm |
yep! Regards Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
27th Nov 2012 2:46pm |
T5bnc Member Since: 13 Sep 2012 Location: S.Wales Posts: 40 |
To be honest when both arms start to freeze i change the setting to face only and point the thing into the back somewhere!
27th Nov 2012 3:47pm |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2166 |
Air con has never been required in a defender since 1947 what with the front air vents and the 5000 holes that came as standard . The biggest mistake LR made was to remove the iconic front vents and then have the cheek to inprint them to make it look as though they still existed , and all for a new dash look ? Personally i hate those 2 big frogs eyes air vents sticking up into the air dooing hee haw all and im about to put nice back lit guages in their place .
27th Nov 2012 10:22pm |
