Home > Maintenance & Modifications > air intake
Page 2 of 2 <12
Steve - It was a good idea but I think what put people off was simply the price nothing more nothing less. No doubt good quality but I think that is the main one.
Thumbs Up Diesel$ Live$ Matter. ⛽️🛢️👨‍🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
Post #182819 7th Nov 2012 11:39am
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
Yer that's fair enough if got mine so I'm not going to worry Thumbs Up
Steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #182820 7th Nov 2012 11:41am
With a 3.2 it deserves nothing less. Thumbs Up Diesel$ Live$ Matter. ⛽️🛢️👨‍🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
Post #182821 7th Nov 2012 11:47am
Inigo
United Kingdom 2012 Defender 110 Puma 2.2 USW Orkney Grey
Ah, the BMC OTA looks a little over the top for what I wanted.
I have an RAI fitted and understand that the air ducting inside the engine bay is not in the slightest bit waterproof. I was planning on sealing this up, but thought it may be easier to replace the complicated and seemingly restricted duct with something wider bore and one piece to avoid having to seal.
Item 7 , dirty air duct looks particularly thin between the cyclone thing and the round section that connects in to the base of the air cleaner. I assume they have designed it this way for a reason - lack of space perhaps, but wondered if there were off the shelf alternatives without going the whole hog and replacing the air cleaner itself. I've always been a bit nervous about the oiled filters and would prefer to keep the standard replaceable paper ones.
Post #182872 7th Nov 2012 3:01pm
bell-auto-services
The problem with the puma and td5 air intakes are the shear size of the pippes.
In the puma's case items 7 particulary and 8 are so restrictive its amasing, if you can make these larger it will for sure help even a standard car.
The BMC filter as most said is a little highly priced i agree but that price is out of my control unless i buy 25 units of which i simply cant afford to stock.
Pete
Post #182949 7th Nov 2012 7:28pm
big steve
Pete
Thumbs Up Thumbs Up 2015 2.2 tdci hardtop xs
Post #182956 7th Nov 2012 7:49pm
ZeDefender
Please can anyone tell me why is it called "dirty air duct"?
I thought the cyclone thing is in the air filter housing? I've removed one - are they breeding? Laughing Tell someone you love them today because life is short.
Post #182979 7th Nov 2012 8:56pm
Inigo
I'm guessing that because this air has not yet passed through the air cleaner, it is still potentially dirty air.
I don't know if it is a cyclone thing, just after the air intake grill and at the beginning of the dirty air duct, but it looks like that shape from the outside. It would make sense to get rid of big lumps and water before getting to the air filter, but I was hoping the RAI would negate the need for this bit.
Post #183008 7th Nov 2012 9:27pm
ZeDefender
Cheers Smile
Good point about the "dirty air" Rolling Eyes
On my Puma 2.4 the air intake is just a squashed pipe (nothing fancy, just constrictive) that gets rounder when it reaches the air filter housing. The only gizmo I found was the propeller thing Pete told me about in the housing itself - it didn't put up much of a fight Thumbs Up
Interestingly (for me at least), with the standard set up, driving along the motorway at a steadyish 100 km/h you can drop the intake temperature at the MAF by one degree just by putting your foot down for a few seconds - ease off and a few seconds later it rises again (can repeat this ad infinitum). Clearly working the engine harder sucks in considerably more air that rapidly cools the MAF down (presumably counteracting continuous warming of the air in the pipework). The extent of this should become clear when the air is taken from the engine compartment (tomorrow hopefully). Tell someone you love them today because life is short.
Post #183018 7th Nov 2012 9:54pm
ZeDefender
So, the little experiment is over and I have answered my own question. I managed to get the filter housing out the way enough to detach the intake pipe and move it above the inlet:
Air being taken in very near the alternator.
Starting temp was 10 degrees (as outside) which increased rapidly to 22 degrees at the same rate as the engine temperature. Stayed constant 22 whilst driving around town, at lights etc. However, on the autobahn it shot up to 28 degrees at 100 km/h and 35 degrees at 140 km/h. Slowing down to 40 km/h, the temperature went down quickly to 22 degrees again. Outside temperature still 10 degrees.
Obvious conclusion - don't (really don't!) get air from the engine compartment. I was expecting that. However, it's also amazing how quickly the compartment heats up as soon as there is load and cools down after (even when the intake is away from the radiator/fan path). I now suspect that my power loss in summer was probably a combination of 30 degrees outside, restriction due to the (not so good) RAI and heating of the air in the engine compartment. The power loss kicked in after I was driving at 140 km/h for a short while - may be explained by the temperature rise in the engine compartment warming the air in the pipes and filter housing by a degree or two. Just an idea...
Does the ECU respond to the MAF temperature?
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Tell someone you love them today because life is short.
Post #183177 8th Nov 2012 2:03pm
theorangebandit
to conclude your experiment I suggest you attach a long pipe to the air box and position it in a place to receive clean air, perhaps the fender cover would be a good space to receive air.this will give cool clean air, perhaps ill improve induction a lot. this is certainly a thought on my mind
Post #242504 10th Jun 2013 2:35pm
bell-auto-services
yes, as well as cylinder head temp.
Post #242509 10th Jun 2013 2:57pm
ZeDefender
Thanks Pete Thumbs Up Tell someone you love them today because life is short.
Post #242549 10th Jun 2013 6:55pm
spudfan
Ireland
You could go low tech. You could fabricate hollow rectangles,3" wide by 1" deep from metal.Measurements can be varied. These are welded to the bottom of the bumper. You extend the bottom and angle it up into the engine bay. When driving this will allow air to be forced up in to the engine bay dissapating the heat. The faster you go the more the air is forced in. Very low tech but it has worked in the past. You can block them up in winter. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #242654 10th Jun 2013 10:49pm
pdv
Belgium 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
hy,
what did you do with the MAF sensor because its one piece with the filter housing ?
grtz from belgium Thumbs Up
Post #502232 8th Feb 2016 7:00pm
Page 2 of 2 <12
