Home > Puma (Tdci) > strange plug under center tray |
ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328 |
TBH the set up does not look good for a proper Sub
2nd Nov 2012 5:26pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19668 |
If you have a bulkhead and don't need the space you could always fit an amp there? Don't be surprised in the seatbox if it doesn't get filthy and maybe even rust a bit. found this out the hard way under my drivers seat.
I'd have also though they could of came up with a better solution than sticking the amp on the back of the cubby. Granted there is limited room but that is the lazy solution imho. Plus you won't be able to see it have hardly any access without pulling it all out or indeed even adjust it. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
2nd Nov 2012 8:39pm |
.... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License |
2nd Nov 2012 8:44pm |
chadjizz Member Since: 25 Apr 2012 Location: sussex Posts: 559 |
dgardel, sorry you have lost me???
custom90steve, mate i would but its a 130 double cab so you would see it and i hate wires everywhere. plus not putting it under the back seats as they are coming out so the Labradors have a massive flattish bed. you have now got me worried about putting in the battery cubby now! |
2nd Nov 2012 9:14pm |
willy eckerslike Member Since: 15 Jun 2009 Location: North yorks Posts: 1789 |
Seal up the battery box thoroughly, there is also room under the drivers seat, i usually fit an air compressor there. Original Member Pie n Pea Club.
110 HCPU Tipper |
2nd Nov 2012 9:18pm |
Sorry, I mention this because my Head Unit has an external control unit which I used to mount in the seat box under the drivers seat until one day had a look at in many months later and found it rusting. Needless to say it's now mounted behind the drivers seat. Might help to seal the seat boxes though. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
2nd Nov 2012 9:19pm |
It's good thing to point out the seat boxes often leak Original Member Pie n Pea Club.
110 HCPU Tipper |
2nd Nov 2012 9:20pm |
I think it's the corner seams that do it. Nothing a bit of silicone wouldn't sort. So long as condensation or damp doesn't become an issue instead. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
2nd Nov 2012 9:23pm |
will make sure i seal it then, thank you for the advice.
its going to be a tight fit, i hope it fits.... |
2nd Nov 2012 10:40pm |
I wrote an uncorrected infos..... sorry Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
3rd Nov 2012 12:49am |
