Home > Puma (Tdci) > Windscreen white line mark |
Yes!!! See bold bits especially! Windscreen out job!
Taken from this thread.... http://www.defender2.net/forum/topic2126.html If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
19th Sep 2012 5:44pm |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10364 |
The plastic sheet between the two pieces of glass, start out in life, White. When moisture gets on into it and delaminates, it returns back to that colour.
Early '90's Citroens used to delaminate a lot and something called flowering also happens |
19th Sep 2012 6:15pm |
If the wuindscreen seal has not been sealed correctly the moisture and crud that permanently sits in there has indeed probably permeated between the laminates. Windscreen out as first step will reveal all. If you go through life with your head in the sand....all people will see is an ar5e!!
19th Sep 2012 7:08pm |
