Home > Technical > Heated Seat upgrade
Page 3 of 5 <12345>
Defender_Td5
1991 Defender 110 300 Tdi USW Stornoway Grey
Forgot to add, I will be using the same circuit to switch the heated mirror element on as well, I think I will adjust it for say a 10 min run for both the mirrors and the screen? Also what gauge cable should I be using?
I really do hate wiring.
Rob
Post #103483 30th Nov 2011 11:06am
PaulMc
Defender_Td5 wrote:
Thanks Paul!
I am also designing a loom for my front heated screen (its the two connection type). I am going to use a timer relay but I need a heavy switching relay to handle the loads. What size would you recommend? 70A?
This the timer relay I have in mind:
http://www.polevolt.co.uk/acatalog/info_74205.html
I am going to switch the relay through one of the post 2002 defender switches.
Regards
Rob
You need to use a 70A relay.
You may have to modify the switch.
The Defender switch and the identical (but different coloured connector and body keyway) Discovery II switch, don't latch, but switch an earth momentarily.
Dyna VT posted an excellent write-up with a diagram on the LRO forum, detailing the fitting of a Defender HFS using the VWP timer relay and a modifed Defender switch.
The switch is modfied so that it switches a live pulse to the timer relay instead of an earth pulse, which the timer relay wasn't compatible with.
The thread is here - http://www.lro.com/forum3/viewtopic.php?f=44&t=60317
. Paul.
Post #103489 30th Nov 2011 11:34am
PaulMc
Rob
For the HFS, Land Rover use 4.0mm2 but, personally, I would probably use 6.0mm2 Smile
The Heated Mirror Kit or Elements should have wiring and/or instructions with them.
Personally, I would use at least 1.5mm2, but would probably opt for 2.0mm2
. Paul.
Post #103500 30th Nov 2011 12:17pm
Defender_Td5
Paul
Thank you for the replies! One more question, when you say 6mm2 do you mean the overall cross section? Such as this:
Thinwall cable 6.0mm. Ref: TW6.0
Operating temp -40 to +105 deg.C. Maximum working voltage 60v.
Nominal current rating 50A. (Derate for long lengths)
Resistance per metre at 20 deg. C: 0.00314R.
Plain copper conductors (84/0.30mm).
Maximum overall diameter of cable 4.3mm.
Sold in multiples of 1mtr.
Price per metre: £1.49 (£1.79 Including VAT at 20%)
Or do you mean the bit I have made BOLD? Which I guess is the actual wire cross section?
Sorry about all the probably stupid questions. Like I said electricity is a dark art to me.
Regards
Rob
Post #103502 30th Nov 2011 12:21pm
PaulMc
Defender_Td5 wrote:
Paul
Regards
Rob
Rob,
The sizes referred to, are the cable's Cross Sectional Area (CSA,) expressed in mm2
For the 6mm2 cable in your example -
The cable is constructed from 84 conductors, each of 0.3mm diameter,
the total Cross Sectional Area of this cable is calculated as -
84 x (0.3 x 0.3) x 3.142 = 5.93838 (or 6mm2)
The other dimension they quote is the cable's overall diameter, which is handy to know when buying conduit, sleeving or cable clips.
. Paul.
Post #103509 30th Nov 2011 1:24pm
explore
United Kingdom 2011 Defender 110 Puma 2.4 DCPU Stornoway Grey
Anybody know where i can get a replacement seat element for the drivers seat, in my 2002 Td5 Defender, can't find genuine ones, exmoor say theirs wont work
Post #105651 8th Dec 2011 9:47pm
Hazza
United Kingdom 1990 Defender 110 Td5 HT Bronze Green
Land Rover will not supply seat base heaters separately for love nor money, even to dealers etc! You either have to buy a new seat base or whole new seat!
Sorry to be the bearer of bad news! 1990 Defender 110 200TDI Camper - now converted to Td5 power
Post #106049 10th Dec 2011 9:30pm
ZeDefender
Good excuse to buy a better seat? Tell someone you love them today because life is short.
Post #106097 11th Dec 2011 9:36am
T1G UP
i don't like my heated seats if i'm honest
My little bum heats up to quick! can you get backrest heaters ie keep the kidleys warm?
Post #106116 11th Dec 2011 11:01am
ZeDefender
Cover the seat and back with a piece of tinfoil - simple physics Thumbs Up Tell someone you love them today because life is short.
Post #106119 11th Dec 2011 11:07am
T1G UP
ok ta Thumbs Up
Post #106120 11th Dec 2011 11:11am
Clemmo
England 2010 Defender 90 Puma 2.4 HT Stornoway Grey
My 2010 Puma lacks heated seats.
I would like to fit them..using this pack
http://www.lrisolutions.co.uk/index.php/la...0-110.html
Sorry if I've missed out....but is this an east DIY job?
Plug n play type of thing?
Cheers Make today a little better than yesterday but not so good as tomorrow....
Defender 90 HT............Pangea Green
BMW X3 Msport............Carbon Black
Mini Electric................Grey. (wow!)
MGB Roadster……..........Vermillion
Honda Benly CD200....Maroon ------------- Chausson 98.........7.5m of fun
Post #164337 25th Aug 2012 2:38pm
Clemmo
Sorry...easy..not east!!!!
Doh Make today a little better than yesterday but not so good as tomorrow....
Post #164339 25th Aug 2012 2:39pm
pouf
Greece 2009 Defender 110 Puma 2.4 SW Zermatt Silver
Post #164345 25th Aug 2012 3:24pm
Romadog
Just been posted. Very interesting. Thumbs Up
http://www.defender2.net/forum/topic10705-180.html
Post #164346 25th Aug 2012 3:33pm
Page 3 of 5 <12345>
