Home > Td5 > Wheezing sound in turns |
td5jusl Member Since: 10 Mar 2024 Location: Berlin Posts: 6 |
Hi dear defender lovers.
I have been having some issues with my 2003 defender td5. It makes a sort of wheezing sound when taking turns. I have attached a video with a link where you can hear the sounds. Has anybody ever experiences similiar issues or may know what this could be? Thank you so much in advance. In addition the ABS and TC lights are on and do not shut off anymore. https://streamable.com/n8vt8o |
10th Mar 2024 3:31pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5428 |
Does it make the sound only whilst moving. Or also when steering stationary?
If all ways look at power steering pump. |
10th Mar 2024 4:49pm |
It only makes the sound while moving, no sound when moving stationary. What would be the difference between the two? Thank you for the replies
10th Mar 2024 4:52pm |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 903 |
The power steering pump would make the sound while stationary as well as when moving. So its likely not the PS pump. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
10th Mar 2024 5:42pm |
Good to know. Thank you for your help. I will then check the wheel bearings and u joints! Will keep you updated in case someone else runs into similiar issues at some point.
10th Mar 2024 5:45pm |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3216 |
Does the noise increase with engine rpm or with vehicle speed?
Does the noise change depending on which gear you are in? Does it change between applying power or engine breaking? Does it change between taking a left or a right turn? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
10th Mar 2024 6:01pm |
Answers below:
Does the noise increase with engine rpm or with vehicle speed? - Noise does not increase in loudness just gets faster, so increases with rpm Does the noise change depending on which gear you are in? - No, the noise remains the same no matter what gear Does it change between applying power or engine breaking? - No the noise remains the same in both sound and loudness no matter applying power or engine breaking Does it change between taking a left or a right turn? - It is much more noticable when taking a left turn, when taking right turns it is softer and less dominant Once again thank you so much for the help from the community. It feels truly unique with Defenders! |
10th Mar 2024 6:22pm |
Indeed, thats what I actually meant in Q1, if noise increases frequency with engine speed.
So with your reply, it seems to be at around engine up till gearbox input shaft. If you can hear the noise by just increasing engine speed while parked, I would take off the auxiliary belt and do a quick test without the belt. But should only be a very short and quick test as the water pump will not be circulating water. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
10th Mar 2024 7:49pm |
The sound is not there when turning in stationary, which means it has to be related to wheel rotation, no? Sorry I am very much a novice in this field. thanks a lot once again.
10th Mar 2024 8:02pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19651 |
Check front diff oil, wondering if it’s CV related but there’s no clicking I assume? Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
10th Mar 2024 8:06pm |
No, there is no clicking sound to hear, it is truly just the sound you hear in the video which appears while turning.
10th Mar 2024 8:07pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1572 |
Sounds like something rubbing to be honest, have you put bigger tyres and not adjusted the steering stop bolts?
10th Mar 2024 8:50pm |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 581 |
Try removing one propshaft and do drive test with central diff lock engaged. Once I had Def with damaged front diff and it was running nice but i bit noisy. Without front prop shaft the noise was gone. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
10th Mar 2024 11:12pm |
