Home > Puma (Tdci) > 2.4 engine rattle - solved |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19645 |
Plug it in and see if there is any codes, but definitely check the turbo heat shield.
Is there any exhaust rattles anywhere? Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
4th Mar 2024 2:31pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16927 |
Mine does something similar (275k miles and nearly all engine parts are original). I suspect it is injector related since adding an injector treatment alters (but doesn't eliminate it).
There is no evidence to suggest that my injectors are loose, but they are undoubtedly worn since each must have discharged over 2500 gallons of fuel through an exceptionally tiny orifice. I have a new set but haven't got around to fitting them yet. |
4th Mar 2024 4:45pm |
BW - Please could you kindly let us know how that goes in future, as it’s always good to know these things.
I’d imagine it’s perhaps a slightly altered injector spray pattern, though the pressure is to spec. I guess even with live diagnostics the pressure would show as roughly correct but the spray pattern not so good. It’s not something that you can really tell unless it’s professionally checked due to the incredibly high pressures concerned so DIY isn’t an option for safety sake. I’d imagine the spray pattern is atomised to a circular pattern, however, perhaps over time this goes sideways a little or oval perhaps. Though off topic, so far so good with the Transit 4x4 clutch, I like it it’s a little heavier in a good way, less slip, and performs well. I’ve not long changed the engine oil, with some nice Castrol C1 professional and genuine service kit. Next on the list is diff oils, and then carefully the transfer box and gearbox. I shall get the brake fluid done for me and clutch fluid. Does anyone think that magnetic diff / transfer box plugs are worth it? Or best just to stick with standard? IIRC, the diffs on mine had standard non mag plugs on, I’ve not touched the rest before to look as I’ve had it serviced for me. I’m glad to finally do it myself as it helps to have the extra knowledge, only some jobs I’d rather not have to do simply because they are a pain like bleeding the clutch but all the same, it’s good to have the knowledge and it’s good to see new members here also wishing to gain a wealth of knowledge. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 Last edited by custom90 on 4th Mar 2024 9:02pm. Edited 1 time in total |
4th Mar 2024 5:01pm |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 1793 |
Magnetic diff drain plugs are worth it, they are not expensive and catch any fine metal particles to stop them circulating around the diff , plus any larger ones that trigger you to investigate where they have come from. I’m pretty sure the transfer box drain plug is already a magnetic drain plug. I believe the MT82 gearbox already has a magnet in its base, however I still fitted a magnetic drain plug to that as well. |
4th Mar 2024 8:55pm |
Sorry for the thread hijack.
Yes, I did think the transfer box had a mag drain plug as standard, but, wasn’t sure if LR commonly fitted them. I am sure my diffs don’t have mag plugs on though, as I had a look at them last time. Does anyone happen to have any links to an MT82 mag drain plug? I may as well get one, as it’s not something that you can change over whenever. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
4th Mar 2024 9:04pm |
foundry 4x4 and 4x4excess both sell them, but look to be out of stock on both sites
4th Mar 2024 9:14pm |
That was what I found the other day when I had a quick look around for some. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
4th Mar 2024 9:22pm |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3035 |
All my magnetic drain plugs are from xcess4x4 but if they are out of stock then Gwyn Lewis usually have them. Most of the LR parts specialists also sell magnetic plugs but I’m not sure which brands they stock. WARNING.
This post may contain sarcasm. |
4th Mar 2024 10:45pm |
Thank you - Gwyn Lewis does a kit for the diffs and transfer box I believe.
Not sure about the MT82 though. LR also do genuine parts diff plugs. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
4th Mar 2024 11:21pm |
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 603 |
TYB500120 is the magnetic diff plugs. If they are not fitted before, beware of your first oil change, they will pick up a lot of debris from normal wear of the diffs.
Regarding transfer box, this has a magnetic plug already, however if I do not know the vehicle (ie I have not driven it exclusively prior to service), I remove the output / PTO cover (six bolts) and inspect the bearing carrier for debris - for some reason when the centre diff is abused, causing the bronze thrust washers to wear / disintegrate, the bronze debris always ends up collecting under the PTO cover. Obviously the magnetic drain plug will not show any bronze particles or debris. |
5th Mar 2024 5:33am |
Just to add, the xcess4x4 plugs are seriously powerful. Knowing Gwyn, his will be decent too. LR ones are not. WARNING. This post may contain sarcasm. |
5th Mar 2024 9:11am |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5427 |
Gwyn sells his on his eBay shop. This can save you a hour or more that a phone call to him always turns into
5th Mar 2024 11:28am |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4506 |
Check the heat shield. Some times the bolts loosen and it will rattle under acceleration. Happened to me. 1982 88" 2.25 diesel
5th Mar 2024 2:32pm |
Or the heat shield can get a little deformed even with fixings as they should be, then it gets very close and can vibrate.
I had a look at mine today as I was there anyway, and all, the fixings were secure but the shield was a bit close, a bit close to the turbo and has headed downward towards the floor. Just bent it a little more up carefully and it was a lot lot better. I’d imagine it often gets confused with the gear stick weights rattle. I think Gwyn’s mag diff plugs will come out on top. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
5th Mar 2024 4:28pm |
