Home > Puma (Tdci) > Passengers Manual Windows - slides down
webbug
United Arab Emirates
Hi
While riding in rough roads, the rear passengers manual windows opens an inch. I believe this is a common issue since I’ve seen it on my friends Landy.
Is there simple fix to this issue?
Thanks
Post #1025992 26th Feb 2024 11:17am
X4SKP
Hello webbug
Please forgive me joining your post as I too would like to know the answer to this.
Firstly I didn't know it was a common problem (Landrover Shocked )
My Wife's 110 has had this on the rear off side (RHD Vehicle), 15mm each time.
My local independent said Oh Yes, we have solved this by using a heavier water pump grease
on the mechanism, counter intuitive, but it worked. My intention is to get the door cards off both
rear doors and have a look / play around, to see if there is any perceived difference and go from there.
Someone may well come along with more insight here so lets see where this goes.
Thanks... Thumbs Up SKIP
Post #1025995 26th Feb 2024 12:10pm
ScarboroughSeadog
United Kingdom 2013 Defender 110 Puma 2.2 DCPU Keswick Green
Oh yes- mine does the same! Wife always suspected our two year olds feet were doing it......I'm not so sure!
Post #1026006 26th Feb 2024 1:17pm
TexasRover
Mine does too and I have the impression that there is a foam block glued to the inside of the door panel in such a way that it creates pressure and friction on the crank handle once fitted.
The foam block can unglue itself and thus leaving the crank handle to fit loosely without any resistance and holding power.
I have changed the window crank mechanism (before I came up with the foam block theory) but that made no difference.
Post #1026016 26th Feb 2024 2:14pm
All second row door windows are prone to it. I initially solved by hooking an elastic bungee round the window winder, this worked but wasn't exactly convenient.
The permanent and best solution was to convert the second row windows to electric lifters. Problem solved, and you can operate the from the front while driving. Thumbs Up
Post #1026018 26th Feb 2024 2:17pm
rustandoil
My fix for this is to orientate the winder handle so that gravity acts on the handle so it doesn't wind the window down
Post #1026020 26th Feb 2024 2:34pm
khamuul
Germany 2007 Defender 110 Puma 2.4 SW Tonga Green
"elastic bungee" - best solution so far.
Winding up and down is still possible, windows stay reliably closed and you get an extra towel hanger for camping. Mr. Green
Post #1026050 26th Feb 2024 6:39pm
That is exactly how I did it before I fitted the electric lifter kit.
Post #1026056 26th Feb 2024 7:29pm
HardCharger
2011 Defender 110 Puma 2.4 SW Stornoway Grey
Asides from the electric window conversion (Which I am saving up for), you can also reposition the handle so it points straight down or as close to it as possible. I found that this stopped my rear windows from inching down on their own. A down side of this is sometimes the rear passenger's knee can hit and turn the handle enough to cause a small gap.
Post #1026101 27th Feb 2024 2:11am
ScarboroughSeadog
Great ideas- the elastic bungee solution looks straightforward and effective...made me smile as well!
Post #1026156 27th Feb 2024 4:06pm
Daysleepers
United Kingdom 2007 Defender 110 Puma 2.4 DCPU Keswick Green
I am installing the elastic bungee solution this evening. Great idea!
Post #1026166 27th Feb 2024 5:21pm
khamuul
You are lucky if you can find an elastic bungee like this one at your local home improvement store for this job:
Post #1026185 27th Feb 2024 7:19pm
Zed
Give it a couple of clockwise turns before fitting and you will have a Twisted performance version. Got to be worth at least an extra 5 bhp. WARNING.
Post #1026206 27th Feb 2024 9:33pm
spudfan
Ireland
This was a built in feature by Land Rover. The Defender had an image of appealing to an older age group and Land Rover were trying to push it towards a younger age group of buyers. The rational behind the self opening window being, that you could take your take your partner for a drive to a secluded spot and have some nudie nookies . The window would be slightly down (automatically, I might add) to allow fresh air into the vehicle during the proceedings and hopefully keep sweating to a minimum. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #1026248 28th Feb 2024 12:21pm
