Home > General & Technical (L663) > Activating ACC, ATPC, TR2 Auto, Park Assist, wheel size etc |
Nicofender Member Since: 16 Jan 2023 Location: Southern Posts: 51 |
I also tried today to activate ACC on a MY23. Did it like you guys said but I always get the Brake error. Tried to write the backup file, it seems the CCF is back to normal but the error persists. Also if I try to clear DTC it doesn’t seem to do anything…
8th Nov 2023 3:33pm |
aquascape Member Since: 08 Mar 2023 Location: Sutton Coldfield Posts: 202 |
After changing CCF files or updating scripts to clear brake error YOU HAVE TO go to Main menu, select DADC module from drop down list, then click on CCF memory and select 'DADC-DriverAssistanceDomainController Learn vehicle configuration (as in the picture) and do the same with the IGM module relearn both of them (picture shown below)
After check DTC, clear DTC on both modules, lock car and leave to sleep for 10 minutes and it will work (this info is from GARY at autosvs) Click image to enlarge MY23 D250 Defender 110 X-Dynamic SE, Carpathian Grey, 7 Seat, Electric Towbar |
8th Nov 2023 3:56pm |
forzahog Member Since: 03 Nov 2022 Location: Fayetteville Posts: 66 |
Script 17 is what they told me to use and that worked for me.
My steps... Connect the obd cable Ignition On Start the app Read the ccf Run the Script (17 in my case) Push the ccf Select DADC from the ccf memory button. Finished I think I then cycled the ignition and then started the rover. After that I could see the icon change when I hit the "Lim" button on the steering wheel. 20MY Defender 110 Fuji White |
8th Nov 2023 4:03pm |
EataPeach4923 Member Since: 07 Jun 2023 Location: USA Posts: 17 |
Where’s the ccf memory button?
8th Nov 2023 4:11pm |
On the first tab.
You can see it on that last screenshot from aquascape. 20MY Defender 110 Fuji White |
8th Nov 2023 4:12pm |
8th Nov 2023 4:55pm |
Awesome guys. Was a 100% user error. Thanks for the picture. I tried script 18 and had a test drive for around a hour and works just fine!
8th Nov 2023 5:14pm |
Glad you have it working. Its not too complicated when you know what to do
A few other scripts to try:- Script 1 - Remember stop/start memory Script 2 - Approach unlocking (only for cars without locking fuel cap) Script 5 - Open rear tailgate from keyfob (wont work with soft close doors) Script 16 - ATPC, TR2 Auto and Dynamic Mode Script 18 - ACC (possibly script 17 for some cars newer than 2021) Script 24 - PIVI Auto parking (maybe needed for park assist, not sure) Script 34 - Defender 007 logo on startup Script 35 or 98 - Enable Wifi Script 37 - 300hp power upgrade for D00/D250 (not sure if this works) Script 115 - Parking Assist (I think this is the script needed to enable park assist) These are all trial, the may work on your car, may not, different cars can be different requirements. Can also of course manually change the CCF files as in the sticky and GAP tool lists MY23 D250 Defender 110 X-Dynamic SE, Carpathian Grey, 7 Seat, Electric Towbar |
8th Nov 2023 5:44pm |
It's a little confusing now that I look at your list. I don't have some of those and the script numbers are different. For example, 115 Parking Assist isn't even on my list. Any idea what values that is changing? 20MY Defender 110 Fuji White
8th Nov 2023 8:39pm |
I think they are vin specific. 115 on mine isn’t actually called park assist. It is called Vertical and horizontal parking system suitable for front and rear 10-12 probes.
I don’t think there is anyway to see what the scripts change. Only way is to look at before and after CCF’s and compare them. MY23 D250 Defender 110 X-Dynamic SE, Carpathian Grey, 7 Seat, Electric Towbar |
8th Nov 2023 10:22pm |
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge MY23 D250 Defender 110 X-Dynamic SE, Carpathian Grey, 7 Seat, Electric Towbar |
8th Nov 2023 10:28pm |
Trying now
9th Nov 2023 5:25am |
According to autosvs this is the script needed for park assist
9th Nov 2023 7:37am |
They got me sorted and all is working well. No luck with the park assist. I see the icon come up but when I click on it it just stays on a blank screen. Oh well.
9th Nov 2023 7:42am |
