Home > Td5 > Defender Td5 gearbox R380 Driving style |
charisme1 Member Since: 23 Oct 2019 Location: Paris Posts: 39 |
Bonjour Mike C, Thank's for your speedy reply. Did you have a chance to drive an R380 from new ? Does it need a momentary pause on neutral before upshifting to 2d and 3d even from new ? Without high reving on the changes and being gentle on the gas ? Cheers ! |
12th Jul 2023 10:03pm |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2064 |
I have never driven a vehicle with an R380 from new. I’ve never experienced any issues with mine over approx. 40,000 miles of ownership. Mine is standard mated to a TD5. I use LR MTF94 and change it more frequently than the service schedule suggests. I don’t drive quickly or aggressively. I think they are fine - notwithstanding that yours may have currently undiagnosed faults/issues.
13th Jul 2023 7:12am |
Hi Screbble. Did you try to drive it like a normal car, hireving and up-shifting quickly ? I have this issue/fault (if it is one) only upshifting from 1st to 2d, and 2d to 3d, only when I rush the gears with high rpm. Never when downshifting. Many thanks for your input
13th Jul 2023 8:21am |
andy2111 Member Since: 17 Oct 2021 Location: Kent Posts: 365 |
I have a reconditioned R380 gearbox and can drive it almost like a normal car. When it gets really hot the gear change gets a bit clunky but it does not need me to pause briefly when shifting. TD5 hardtop to Puma inspired Poptop - my build thread
2002 110 TD5 Hardtop ¦ Full Puma interior ¦ Carpathian grey / Santorini black ¦ X-Vision-X poptop |
13th Jul 2023 9:19am |
Mike c Member Since: 11 Aug 2017 Location: Maldon, Essex Posts: 905 |
Hello charisme1, no I am unable to comment about an owned from new r380. 2004 Defender 90 Td5 CSW 2002 Discovery 2 td5 GS (gone) 1994 Defender 90 300Tdi CSW (gone) |
13th Jul 2023 9:36am |
I don’t tend to rev too highly, but I’m not consciously not driving like a ‘normal car.’ I haven’t really thought about it properly, but I might pause slightly when passing through neutral. I can’t say I’ve noticed anything unusual when upshifting. I’ll need to go out later and pay attention! Having said all that, I still don’t think it feels fundamentally different to the other cars in our household (which aren’t Defenders!) but maybe I’ve just got a good gearbox… I hope you solve your problem |
13th Jul 2023 8:04pm |
murph81 Member Since: 11 Sep 2022 Location: Ireland Posts: 63 |
I have noticed this issue with my 110 lately, the gearbox has only done 56k miles from new.
14th Jul 2023 12:57am |
Hi murph ! Did you change the oil ? As your gearbox seems new with only a few miles on it. Or maybe this a characteristic behavior of R380. Means not to high rev while up shifting quickly on lower gears. Maybe box needs to be gentle with it, with a pause on neutral for a second and no agressive rpm. Anybody here drove a R380 from new that can comment ? Thx
14th Jul 2023 9:48am |
LandymanStefan Member Since: 30 Aug 2017 Location: Surrey Posts: 862 |
I recently had a bit of a snatchy/rough box at high rpms, much more noticeable after my remap. I changed the fluid (Granville mtf94) to genuine Land Rover mtf94 and have had a huge improvement. It’s not so buttery when it’s at high temps so I’ve recently fitting a gearbox cooler and I’m hoping that’ll keep the shifts smooth and potentially stop the oil from being cooked.
14th Jul 2023 1:39pm |
Fitting an R380 cooler has certainly helped protect the oil in Miffy
14th Jul 2023 1:41pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1572 |
I wouldn’t give granville oil to my worst enemy, it’s not regarded as a good product
14th Jul 2023 2:46pm |
Whereas I WOULD give it to my worst enemy
14th Jul 2023 7:04pm |
Haven't changed the oil in my ownership, have only put 2k miles on it so far but I will be doing it soon once I sort some good quality oils. I have tried shifting a bit more gingerly today, hard to know yet. |
14th Jul 2023 9:45pm |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 4966 |
yeah these boxes don't like been rushed, i always sort of pause as you say to get the best changes. learned this with the 300 TDi. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
15th Jul 2023 2:37am |
