![]() | Home > Puma (Tdci) > Transmission oil change |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21044
For the price it’s well worth doing, obviously just be sure to use exact quantities and spec.
GL4 for example in the MT82 as an example, and exact quantity. Transfer box and axles can be fill to filler. 1 shot swivel grease is a good thing too. With the garage services I think there are many things that get left, bi annual brake & clutch fluid just as as an example, plus parts quality scrimped, cheaper oils etc. Equally they do need to make a profit, but will also say depends on what the customer requests. LR explicitly did not include brake and clutch fluid with the typical service, even though it is best done every couple of years as it gets hydroscopic, not to mention that the bleed valves can seize over time and things like prop greasing doesn’t get done. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
| lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3553
l've done the swivel grease as well.
The engine oil looked new, as did the oil and fuel filters. |
| All times are GMT |
