Home > My Defender > The v10 defender
T3DDY14
United Kingdom 1998 Defender 110 300 Tdi HT Alaska White
The v10 defender
Hi all, im not sure anyone has done one of these in a defender, i know a patrol swap and a corvette has been done but not a defender...
So a v10tdi in a defender, "you must be crazy" is what you're probably thinking and its what i think every day now as i deal with this daunting task.
But im not joking and this isnt a troll i really am putting a twin turbo v10 from a touareg into a defender...
There is a story on why this all started but its very long and you're probably wanting some photos or proof of this madness, so here you go :
The inital moving into the place of where this swap will happen:
The delivery of the second engine:
Pulling out the original engine:
Pulling out the 300tdi:
Test fitting the v10:
Making the engine mounts:
The engine in its final positon:
And proof its held under its own weight:
Now im a uni student so i only get to work in this in my free time and am open to suggestions and help, ive got a gearbox mount tacked and ready for final welding, and need to make custom props, im currently trying to find a solution for the handbrake, and intercoolers as i want to use a td5 radiator as these are fairly easy to mount. If tberes any advise it will be greatly appreciated and i will try to keep this thread updated on any progress!
Post #1077520 14th Oct 2025 9:43pm
jst
Pics don't work for me Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1077525 14th Oct 2025 10:07pm
T3DDY14
Cant seem to load for me either, no clue whats going on, removed the tags for now so the links still work
Post #1077526 14th Oct 2025 10:08pm
Pickles
Hello from Aussie, amazing work, I admire your courage in carrying out such a complex conversion. How did you acquire the necessary skills?
But, great work, updates will be appreciated.
Post #1077538 14th Oct 2025 11:14pm
T3DDY14
General tinkering on other cars, have replaced multiple engines on other cars including the tdv6 on a disco 3 with the body on, a mitsubishi legnum and a e39 540i estate
Post #1077539 14th Oct 2025 11:35pm
Co1
Watching this thread with interest. Good luck!!
Post #1077544 15th Oct 2025 6:22am
Martin
Site Admin
Images fixed for you  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1077545 15th Oct 2025 6:39am
Stacey007
Hats off to you.
Would not know where to start, and your certainly right I have not heared of that ngine in a Defender,
How much torque will that have, I have another car with a 4.0d V8 and its 900lbs ft.... certainly moves
Keep up the pictures... Thumbs Up
Post #1077549 15th Oct 2025 9:01am
tommobot
Love it! Looks bloody excellent, though don't envy you with the wiring of the engine.
Presume your using an autobox, with the P do you 'need' a handbrake? - Potentially a small caliper on the rear axle for MOT purposes if it was an issue?
I was recently daydreaming about Audi RS6 V10 in a defender, with the main access in the original car being that the engine needs to be removed to do anything.
In the Defender, and as with this V10TDI, with the wings removed I would envisage superb access all around the engine Bow down
Post #1077553 15th Oct 2025 10:15am
T3DDY14
Thank you so much! What did i do wrong? Defender 110 300tdi hard top
Post #1077562 15th Oct 2025 10:45am
T3DDY14
To answer multiple questions:
Whats the power of this thing?
Supposedly 430bhp and 1020nm, this is what the prev owner had said as hes had it remapped with hybrid turbos on and so far with the work i can see on the engine i believe him
Access:
The entire idea behind it was in the touareg and phaeton its near impossible to do anything without removing the engine bjt now theres plenty of space even with the wings on, i have managed to chage the rear turbo actuator module in situ as i had snapped an arm while manovering the engine into place, something impossible to do on a touareg without droppig the engine.
Handbrake:
Im im two thoughts, either try and adapt the drum brake to the back of the touaregs transfercase or add a secons caliper to the rear axles dedicated as a handbrake (this is ontop of the original so there would be two calipers per rotor), to let me upgrade the brakes later on.
And as for the "p" instead of a handbrake im not sure on mot.purposes if just using the parking function would pass an mot as i would like to use this rig for towing/recovery and the occasional lane Defender 110 300tdi hard top
Post #1077565 15th Oct 2025 11:01am
jst
line lock for locking wheels? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1077571 15th Oct 2025 11:31am
T3DDY14
Im not quite sure on mots as i know they cant be hydraulic, if anyone knows if they are or not it would save alot of money and fabbing if i can use one Defender 110 300tdi hard top
Post #1077573 15th Oct 2025 11:37am
Dinnu
Amazing project. With that power and torque, I hope you also budgeted for upgraded diffs and shafts.
As far as I know the parking / hand brake has to be independent from the service brake. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1077580 15th Oct 2025 12:45pm
T3DDY14
For the moment the standard axles are staying as i believe they are already salisbury ones and debating on getting ashcroft to upgrade them or go to patrol axles Defender 110 300tdi hard top
Post #1077581 15th Oct 2025 12:49pm
