![]() | Home > My Defender > The v10 defender |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8473 ![]() ![]() ![]() |
Pics don't work for me Cheers
T3DDY14 Member Since: 23 Jul 2020 Location: Kent Posts: 48 ![]() ![]() ![]() |
Cant seem to load for me either, no clue whats going on, removed the tags for now so the links still work
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3802 ![]() ![]() ![]() |
Hello from Aussie, amazing work, I admire your courage in carrying out such a complex conversion. How did you acquire the necessary skills?
But, great work, updates will be appreciated. |
General tinkering on other cars, have replaced multiple engines on other cars including the tdv6 on a disco 3 with the body on, a mitsubishi legnum and a e39 540i estate
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3784 ![]() ![]() ![]() |
Watching this thread with interest. Good luck!!
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6722 ![]() ![]() ![]() |
Images fixed for you
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3891 ![]() ![]() |
Hats off to you.
Would not know where to start, and your certainly right I have not heared of that ngine in a Defender, How much torque will that have, I have another car with a 4.0d V8 and its 900lbs ft.... certainly moves Keep up the pictures... ![]() |
tommobot Member Since: 15 May 2018 Location: Stratford Upon Avon Posts: 44 ![]() ![]() |
Love it! Looks bloody excellent, though don't envy you with the wiring of the engine.
Presume your using an autobox, with the P do you 'need' a handbrake? - Potentially a small caliper on the rear axle for MOT purposes if it was an issue? I was recently daydreaming about Audi RS6 V10 in a defender, with the main access in the original car being that the engine needs to be removed to do anything. In the Defender, and as with this V10TDI, with the wings removed I would envisage superb access all around the engine ![]() |
Thank you so much! What did i do wrong? Defender 110 300tdi hard top |
To answer multiple questions:
Whats the power of this thing? Supposedly 430bhp and 1020nm, this is what the prev owner had said as hes had it remapped with hybrid turbos on and so far with the work i can see on the engine i believe him Access: The entire idea behind it was in the touareg and phaeton its near impossible to do anything without removing the engine bjt now theres plenty of space even with the wings on, i have managed to chage the rear turbo actuator module in situ as i had snapped an arm while manovering the engine into place, something impossible to do on a touareg without droppig the engine. Handbrake: Im im two thoughts, either try and adapt the drum brake to the back of the touaregs transfercase or add a secons caliper to the rear axles dedicated as a handbrake (this is ontop of the original so there would be two calipers per rotor), to let me upgrade the brakes later on. And as for the "p" instead of a handbrake im not sure on mot.purposes if just using the parking function would pass an mot as i would like to use this rig for towing/recovery and the occasional lane Defender 110 300tdi hard top |
line lock for locking wheels? Cheers
Im not quite sure on mots as i know they cant be hydraulic, if anyone knows if they are or not it would save alot of money and fabbing if i can use one Defender 110 300tdi hard top
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3640 ![]() ![]() ![]() |
Amazing project. With that power and torque, I hope you also budgeted for upgraded diffs and shafts.
As far as I know the parking / hand brake has to be independent from the service brake. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
For the moment the standard axles are staying as i believe they are already salisbury ones and debating on getting ashcroft to upgrade them or go to patrol axles Defender 110 300tdi hard top
