![]() | Home > Tdi > 200TDI 110 wiring loom. What’s this relay for? |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6723 ![]() ![]() ![]() |
Factory wiring never used blue crimps like that.
Therefore not original factory, it could be someone has replaced the HRW relay but heated rear window wiring colours don't match what's there, but who knows what is going on out of shot. Where do the wires come from/go to? ![]() ![]() |
I Like Old Skool Member Since: 23 Feb 2015 Location: Manchester Posts: 881 ![]() ![]() ![]() |
Totally none original wiring. Does the fuse you are holding feed to the relay? If it does, try pulling the fuse and then see what stops working.
Diesel Power Member Since: 04 Mar 2025 Location: Midlands Posts: 19 ![]() ![]() ![]() |
Thanks Martin Had a brief look and one wire goes up to the instrument panel, another into the ignition barrel and one into the engine bay. Need to investigate further. |
That’s a good idea. I’ll try that. Possibly if it’s rear windscreen though I won’t be able to tell as I have neither a rear wiper nor a heated screen 😄 |
Mr.Jimbo Member Since: 20 Jun 2024 Location: Rugby UK Posts: 35 ![]() ![]() ![]() |
Long shot but could be additional lights, have seen people take the feed from the main beam tell tale bulb before to switch on additional spots etc through a relay. 2003 TD5 110 CSW Instagram: e12_hue |
Can’t seem to work out what it’s for but as it’s not factory I might just take it out to tidy up the wiring before the dash goes back on. If I notice something isn’t working then I’ve found the issue!
