![]() | Home > Puma (Tdci) > Engine Oil for 2.2tdci and 2003 td5 |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1678 ![]() ![]() |
alas no you need low saps c1 5/30 for a 2.2 puma
Land Rover Genuine Engine Oil STC50527 is their part number, it does do a few other lr 4x4. plenty of other brands do the same spec for sensible money. it would be a waste in a td5. wrong oil in the 2.2 can block up dpf etc and cause other issues. td5 are happy with most grades of 5/30. older worn engines or ones that are tuned/ worked hard can use 10/40 or 5/40 as well. |
roche1800 Member Since: 07 Apr 2020 Location: derbyshire Posts: 436 ![]() |
Thanks for the reply advising on C1.
Becoming confused as Opie recommend a C4…🤷🏼♂️ https://www.opieoils.co.uk/c-1038-acea-c4-diesel-engine-oil.aspx |
Iktank Member Since: 08 Nov 2014 Location: Porthcawl Posts: 247 ![]() ![]() ![]() |
yeh Opie also told me that C4 supersedes the C1 as basically C1 is not recognised any more but is still made. I purchased the Millers Titan C1 which they confirmed is fully compatible with the Millers XF C1 (which is no longer available)
c1 and c4 are both low saps, c4 is mainly specced for citroen ive read but we dont have any trouble getting c1 locally to us at the minute.
opie or any of the main oil makers and sellers should be fine and their advice should be spot on. |
Roukmuth Member Since: 25 Sep 2022 Location: Aurillac Posts: 7 ![]() ![]() ![]() |
For the Defender 2.2 tdci (with DPF) ➔ SAE 5W30 specification Ford WSS-M2C934-B.
See the tutorial "Engine oil change on Defender Td4 2.2 DPF" ➔ https://meca1.co.uk/dm1-ad-vidangetd4/ For the Defender Td5 ➔ SAE 5W30 A1/B1 or A5/B5 See the tutorial "Which oil for your Td5 engine ?" ➔ https://meca1.co.uk/dm1-an-huiletd5/ |
Has anyone used or know of this engine oil:
https://ebay.us/m/tbN7lP ![]() Click image to enlarge Thanks for explaining low saps and C4 supersedes C1 |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2507 ![]() ![]() ![]() |
You can also pick a low saps oil but with higher viscosity protection such as Total Ineo MC3 5W30 (low saps and HTHS>3.5). Puma 110" SW
