Home > Puma (Tdci) > Engine Oil for 2.2tdci and 2003 td5
roche1800
Please can someone help me with ideally the same engine oil to use on 2 x 2.2 Tdci (2012 & 2016) AND a 2003 Td5.
Would this be ok please:
Millers Oils Trident Professional 5W-30 C3 Fully Synthetic Engine Oil
Post #1077160 9th Oct 2025 5:03pm
Mdm
alas no you need low saps c1 5/30 for a 2.2 puma
Land Rover Genuine Engine Oil STC50527 is their part number, it does do a few other lr 4x4.
plenty of other brands do the same spec for sensible money.
it would be a waste in a td5. wrong oil in the 2.2 can block up dpf etc and cause other issues.
td5 are happy with most grades of 5/30. older worn engines or ones that are tuned/ worked hard can use 10/40 or 5/40 as well.
Post #1077164 9th Oct 2025 5:46pm
roche1800
Thanks for the reply advising on C1.
Becoming confused as Opie recommend a C4…🤷🏼‍♂️
https://www.opieoils.co.uk/c-1038-acea-c4-diesel-engine-oil.aspx
Post #1077165 9th Oct 2025 5:51pm
Iktank
Wales 2014 Defender 90 Puma 2.2 SW Corris Grey
yeh Opie also told me that C4 supersedes the C1 as basically C1 is not recognised any more but is still made. I purchased the Millers Titan C1 which they confirmed is fully compatible with the Millers XF C1 (which is no longer available)
Post #1077172 9th Oct 2025 6:57pm
Mdm
c1 and c4 are both low saps, c4 is mainly specced for citroen ive read but we dont have any trouble getting c1 locally to us at the minute.
opie or any of the main oil makers and sellers should be fine and their advice should be spot on.
Post #1077180 9th Oct 2025 8:02pm
Roukmuth
France 2002 Defender 110 Td5 SW Epsom Green
For the Defender 2.2 tdci (with DPF) ➔ SAE 5W30 specification Ford WSS-M2C934-B.
See the tutorial "Engine oil change on Defender Td4 2.2 DPF" ➔ https://meca1.co.uk/dm1-ad-vidangetd4/
For the Defender Td5 ➔ SAE 5W30 A1/B1 or A5/B5
See the tutorial "Which oil for your Td5 engine ?" ➔ https://meca1.co.uk/dm1-an-huiletd5/
Post #1077207 10th Oct 2025 7:50am
roche1800
Has anyone used or know of this engine oil:
https://ebay.us/m/tbN7lP
Thanks for explaining low saps and C4 supersedes C1
Post #1077231 10th Oct 2025 11:59am
MK
You can also pick a low saps oil but with higher viscosity protection such as Total Ineo MC3 5W30 (low saps and HTHS>3.5). Puma 110" SW
Post #1077233 10th Oct 2025 1:07pm
