Home > General & Technical (L663) > GAP tool question
lightning
GAP tool question
l know the GAP tool stores the original settings but does it store your changes?
I had to reset my Defender back to factory settings and l was wondering if l can re-install the changes from the GAP tool of if l have to go through the list and do them all again manually.
Post #1076952 6th Oct 2025 1:38pm
Down & Dirty
I believe it only stores the original 1st file, so you’d have to re input any changes you require Thumbs Up 26MY SE 90 in Woolstone green on order.
24MY HSE X-Dynamic 90 Carpathian Grey
Post #1076959 6th Oct 2025 2:05pm
Defendit..
Netherlands
I make a Copy everytime I change CCF.
So at least you can find the changes you made. No Mud flaps for my 90.!
P300S MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods..
Post #1076969 6th Oct 2025 5:03pm
DefenderMidlands
You can save the ccf files you want to change in favourites and then easily access them all MY25 D350 Defender 110 X, Carpathian Grey, 7 Seat, Electric Towbar
Post #1076983 6th Oct 2025 8:17pm
Down & Dirty
Didn’t know that but,
Good to know Thumbs Up 26MY SE 90 in Woolstone green on order.
Post #1076984 6th Oct 2025 8:24pm
lightning
Since the vehicle came back from having the inverter replaced l've used the GAP tool to change the stop/start to remember the last setting but it doesn't work.
lt worked before. ls there something else l need to do.
Post #1076998 7th Oct 2025 11:23am
Down & Dirty
Done the normal privi reset?
Must admit did the the wife’s evoque took 24 hrs to work even after several resets and locking and letting go to sleep 26MY SE 90 in Woolstone green on order.
Post #1077003 7th Oct 2025 12:59pm
lightning
Yes did the reset but not actually driven it anywhere yet. Maybe it will work after l have done a journey.
EDIT
Now working after going for a drive.
Post #1077009 7th Oct 2025 2:54pm
