![]() | Home > General & Technical (L663) > GAP tool question |
Down & Dirty Member Since: 15 Sep 2023 Location: Somewhere outback Posts: 112 ![]() ![]() |
I believe it only stores the original 1st file, so you’d have to re input any changes you require
![]() 24MY HSE X-Dynamic 90 Carpathian Grey |
Defendit.. Member Since: 09 Aug 2020 Location: 's-Hertogenbosch Posts: 473 ![]() ![]() |
I make a Copy everytime I change CCF.
So at least you can find the changes you made. No Mud flaps for my 90.! ----------------------------------------- P300S MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. |
DefenderMidlands Member Since: 08 Mar 2023 Location: West Midlands Posts: 287 ![]() ![]() |
You can save the ccf files you want to change in favourites and then easily access them all MY25 D350 Defender 110 X, Carpathian Grey, 7 Seat, Electric Towbar
Didn’t know that but, Good to know ![]() 24MY HSE X-Dynamic 90 Carpathian Grey |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3503 ![]() ![]() |
Since the vehicle came back from having the inverter replaced l've used the GAP tool to change the stop/start to remember the last setting but it doesn't work.
lt worked before. ls there something else l need to do. |
Done the normal privi reset?
Must admit did the the wife’s evoque took 24 hrs to work even after several resets and locking and letting go to sleep 26MY SE 90 in Woolstone green on order. 24MY HSE X-Dynamic 90 Carpathian Grey |
Yes did the reset but not actually driven it anywhere yet. Maybe it will work after l have done a journey.
EDIT Now working after going for a drive. |
