Home > Puma (Tdci) > Is the 2.2TDCI Serp Belt Swap Procedure The Same as the 2.4?
big110
 2014 Defender 110 Puma 2.2 SW Keswick Green
I posted this in the sticky, but curious if the procedure for the serpentine belt replacement on the 2.2 TDCI is identical to the 2.4 TDCI.
The sticky references the 2.4 motor and the instructions are great, Id like to know if its the same so I can print them and put them in the truck with my spare belt.
Thank you
Post #1076914 5th Oct 2025 5:13pm
big110
bump
Post #1076967 6th Oct 2025 4:58pm
Siwynne
Process is basically the same but vac pump is cam driven on a 2.2 and belt driven on a 2.4 so belt path is slightly different
Post #1076985 6th Oct 2025 8:28pm
big110
ahhh, so as long as you follow the original belt path you are ok!
Post #1076987 6th Oct 2025 8:41pm
macfrank
maybe uselful:
Post #1077087 8th Oct 2025 8:39pm
