![]() | Home > Puma (Tdci) > Is the 2.2TDCI Serp Belt Swap Procedure The Same as the 2.4? |
big110 Member Since: 02 Nov 2016 Location: Worldwide Posts: 401 ![]() ![]() ![]() |
bump
Siwynne Member Since: 04 Nov 2016 Location: West lancs Posts: 623 ![]() ![]() |
Process is basically the same but vac pump is cam driven on a 2.2 and belt driven on a 2.4 so belt path is slightly different
ahhh, so as long as you follow the original belt path you are ok!
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1135 ![]() ![]() ![]() |
maybe uselful:
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
