Home > Puma (Tdci) > Bog std 2.4 puma … collapsed new intercooler hoses
cypermethrin
United Kingdom 2008 Defender 110 Puma 2.4 SW Bronze Green
So….. replaced both LH and RH intercooler hoses after one split. no drama.
Until today when seemingly at motor speed cloud of white smoke and evidence of driver’s side hose collapsing on itself. Otherside is weak in similar position
Forscan showed P006A:00-68 MAP mass or volume air flow correlation bank 1
So is this due to the replacement hoses being non OEM rubbish OR can a fault MAF distort the hoses ?
TIA
Post #1076592 30th Sep 2025 8:22pm
Did you ensure there was no caps or anything in the pipes before fitting?
They do have temporary blanking caps for shipping and or fitting IIRC with some.
Obviously they need to be removed prior to and or during fitted.
They are often used for cleanliness during fitting too, to prevent any dirt getting in right until the point of actually putting the pipe on.
As with Defenders it’s easy to get some dirt go in pipes just fitting them, I sometimes use a disposable glove to put over the end of a removed pip unit refitted, obviously must be removed just before putting back on, but it stops anything getting in open ended pipes. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1076594 30th Sep 2025 8:35pm
cypermethrin
Thanks for your reply
Fair question but all end caps removed prior to fitting
And AA removed and checked hose and refitted etc
Post #1076595 30th Sep 2025 8:40pm
There can be some that work there way inside, any possibility anything was accidentally left when fitted?
Check the MAF wiring nr the plug and you can also clean it. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1076598 30th Sep 2025 9:04pm
cypermethrin
UPDATE :
Removed both LH and RH intercooler hoses - no obstructions
Checked dirty air feed to air filter box and hose to turbo - no obstructions
Air flow through intercooler via smoke test confirms no blockage
What else should I be checking ?
Post #1076664 1st Oct 2025 7:00pm
