Home > Maintenance & Modifications > LED headlight, MOT failure and type approval.
DC101
United Kingdom 2005 Defender 110 Td5 CSW Zambezi Silver
Hi All,
My TD5 came with LED headlights fitted when I purchased the vehicle 3 years ago. After going through at least 3 MOTs at different garages the lights failed this year alone due to beam pattern(or blurriness of).
So I’ve taken the LED units out and can find no brand on shell of units and the only markings as per below photo. Can someone confirm that they aren’t type approved?
But how come they passed earlier MOTs…. (Don’t answer..!).
So as decent approved LED lamps look to cost a packet, could be reverting back to crystal lens and wipacs. Is it straight plug and play as also a loom for the DRLs on the LED lamp. Do I just ignore that?
Thank you for looking
Rob
Post #1076395 28th Sep 2025 1:15pm
Retroanaconda
There are many LED units out there with fake approval markings - yours included.
A proper E-mark looks like this:
Post #1076401 28th Sep 2025 2:00pm
DC101
Thanks for the confirmation.
My lights won’t be going back on then, though I didn’t mind the DRL aspect of them.
I’ll look at the options, though I suspect SWMBO will side on the crystal wipacs!
Post #1076412 28th Sep 2025 2:33pm
They passed previous MOT tests because the test doesn't include checking that lights are correctly type-approved and E-marked, it only checks for beam pattern and that LED bulbs haven't been fitted in H4 light units.
The fact a vehicle passes an MOT test doesn't make it roadworthy and legal.
Post #1076422 28th Sep 2025 4:09pm
Johan_B
Sweden 2007 Defender 110 Puma 2.4 CSW Tonga Green
https://www.osram.co.uk/ecat/NIGHT%20BREAK...P_4069705/
I think these should be legal in the UK. Combine with Wipac original lenses and the Whole Vehicle Type Approval should be maintained.
Not sure how the DRL is working. In Sweden all vehicles are equipped with an automatic dipped beam system, fitted by the general agent on arrival to Sweden. This ensures that the dipped beam is on in the first and third position of the light switch. Maybe the DRL system is similar and can be used to achieve the same?
Post #1076464 29th Sep 2025 11:47am
Johan_B wrote:
... I think these should be legal in the UK. Combine with Wipac original lenses and the Whole Vehicle Type Approval should be maintained. ...
I don't think so. There is nothing in the linked Osram web page, nor the subsequent compatibility listing page that I can see that gives me the slightest reason to think that these are legal in EWVTA vehicles.
The fact that the word "vintage" features heavily in the product name and description casts further doubt.
As I understand the UK situation at present it is quite simple, if a vehicle that is subject to EWVTA was type-approved with a light unit that had an halogen light source, then only a halogen light source can be used in that light unit. You can replace the whole unit with a type approved LED unit (subject to certain conditions according to the lumen output of the light), but you cannot substitute any form of LED light source for the halogen bulb in a halogen unit.
Any vehicle first used before 1st April 1986 can use LED light sources in halogen units since they are not legally required to be type approved. Any vehicle first used on or after 1st April 1986 can have the complete light units replaced with LED units, but cannot simply change the light source in an existing unit.
Whilst many people do use LED "bulbs" in H4 units, and they provide excellent lighting, the risk is firstly that you will now fail the MOT test (it is a specific check now) and secondly that you are technically not roadworthy and if stopped could face a number of generally unsavoury penalties.
Post #1076467 29th Sep 2025 1:23pm
Johan_B
Good clarification BW.
The UK webpage only had this variant listed and for rest of Europe there are more options listed, without the word "Vintage", so I thought it was the only one that passed in UK. Maybe it is only applicable for cars registered before 1986 as you mention.
There is a procedure to follow and certain documents to be carried in the vehicle to prove that these lights conform to the requirement. One of these documents is from MoT in Sweden where it explicitly says that these units, if condition x, y and z are fulfilled, are approved in this vehicle.
In Sweden it is the other way around than what you describe, we can never replace a halogen unit with a LED unit. But with this 'bulb', we can still upgrade to led as long as we keep the original reflector. As far a I am aware it's only with this Osram Night Breaker that can be done.
Post #1076468 29th Sep 2025 1:52pm
Johan_B
Just read the Q and A on the Swedish site:
Do I need to change back to halogen if I go abroad?
No, as long as the vehicle is legal in the country of registration, no other country can direct claims toward it. The exception being United Kingdom, then the LED has to be removed and the original halogen light source be mounted.
Post #1076469 29th Sep 2025 2:08pm
macfrank
Interesting. I remember the days when we had to stick plastic lenses to our continental LHD headlights when visiting the UK so the asymmetrical beam wont blind anyone. I don‘t think it was the same the other way round Whistle p
Post #1076474 29th Sep 2025 3:32pm
Mo Murphy
Interestingly macfrank, we in the UK think the same 😁 I've never seen a LHD vehicle in the UK with headlight sections blanked out. Never ever, not even one ! On the other hand those of us who travel in Europe, certainly in the group I travel with are always conscientious with regards to Masking headlamps. Odd, what ?
50 Shades of Pennine Grey
Post #1076476 29th Sep 2025 4:25pm
macfrank
haha, indeed Laughing My memories are from the 1980s. After that I only had motorcycles for a decade and now I thought this was a thing of the past. Just looked it up and apparently it is still required? Embarassed
https://www.adac-shop.de/eurolites-englandaufkleber
Post #1076478 29th Sep 2025 4:50pm
Retroanaconda
A lot of vehicles have flat beams now so not required for them but I also have never ever seen a foreign vehicle in the UK with headlight deflectors. I have however been dazzled by plenty.
Post #1076527 30th Sep 2025 8:51am
90 Dreamer
certainly brothers Disco, he is able to convert the headlight aim from RHD to LHD and then back again when he returns........
Post #1076539 30th Sep 2025 10:18am
I understand that many modern high-end vehicles now do this automatically since they know where they are through GNSS and hence know which way to dip. A co-worker's Audi apparently changes the language of its sat-nav voice instructions at national borders too, which is harder to understand (if you're an English speaker when you reach the border you probably still are over the border).
Post #1076542 30th Sep 2025 10:53am
TexasRover
I think a lot of modern vehicles have such sharp (pin-like) lighting they blind you no matter what. While in the past people might flash you when driving 'overseas' without the stickers now I think people have given up and accept the blinding.
Interesting I recall when I did my driving lessons in the 80's I was told to use the handbrake when standing still as to 'not blind the people behind you with your brake light'.. Obviously automatics were not much of a thing then, neither was the 3rd raised brake light. Man we were real pussies then!
Post #1076558 30th Sep 2025 1:41pm
