![]() | Home > Td5 > Turbo seal kit |
DefenderCan Member Since: 25 Nov 2023 Location: Canada Posts: 47 ![]() ![]() ![]() |
https://www.ebay.com/itm/267381011368?var=...7303baeaba
There you go! |
Mr.Jimbo Member Since: 20 Jun 2024 Location: Rugby UK Posts: 35 ![]() ![]() ![]() |
I think the seals your mechanic is referring to are the internal oil seals around the centre bearing in the turbo housing itself. I've never seen these advertised for a TD5, but a Turbocharger specialist might be able to source them.
When the central seals wear, the turbo can suck oil from the bearing feed under vacuum conditions which leads to burning the oil in the exhaust and smoke. Can also cause coking if it's run for a long time in that condition. 2003 TD5 110 CSW Instagram: e12_hue |
Scottyboy Member Since: 09 Jul 2024 Location: Kaiserslautern Posts: 20 ![]() ![]() ![]() |
DefenderCan, thank you.
I’m wondering what is the purpose of this kit? https://ebay.us/m/NlvQmU If I end up replacing CHRA, is there another seal kit? I’m guessing the CHRA will come with them, but not sure. Thank you again. |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6038 ![]() ![]() ![]() |
Those seals are for when you remove the turbo from the manifold etc and then refit. 1999 Defender TD5 110
Notyalc Member Since: 27 Jul 2018 Location: Northumberland Posts: 177 ![]() ![]() ![]() |
I would say best get a reman turbo.
